Intel® Arc™ Discrete Graphics
3499 Discussions
The frequency in the game drops Again
Raifart
Hello, I'm resetting my graphics card's clock speed again. I updated to driver 32.0.101.8247 today.
Everything seemed to be working, but then the same thing happened again. I already created a thread about it. I did a quick check and everything worked, but now it's happening again.
What's interesting is that the game didn't crash, but after entering the IGS overclocking settings, I got a message about "unstable settings."
Disabling overclocking during the game didn't help, so I recorded a CAPframe file. At the end of the recording, I disabled path tracing, and the frame rate was restored!
KentRusselP_Intel
Hi Raifart,
Thanks for reaching out through the Intel Community Forum! I appreciate your message and want to let you know that I’m here to help with your concern. Also, thank you for sharing the CrapFrameX from your game along with the related images — I’ll review the details and look into the issue for you.
In the meantime, if you have any other questions or need more help, feel free to reach out anytime.
Kent Russel P.
KentRusselP_Intel
Hi Raifart,
Thank you for your continued cooperation. To assist you further, please provide a new set of CapFrameX logs with a minimum duration of 300 seconds, ensuring that no overclocking is applied and that you're using the latest graphics driver.
Additionally, please install graphics driver version 32.0.101.8132, and capture another CapFrameX log under the same conditions—at least 300 seconds and no overclocking.
Could you also confirm whether you performed a Display Driver Uninstaller (DDU) cleanup before installing the latest driver version 32.0.101.8247?
To better understand your system configuration and provide accurate support, we kindly ask you to share updated Intel® System Support Utility (SSU) logs. These logs contain essential details about your hardware and software environment.
Please follow these steps:
  1. Download and run the Intel® SSU application.
  2. The tool will generate a text file with your system information.
  3. Refer to this guide for detailed instructions: Help Guide for the Intel® System Support Utility
  4. Once completed, please attach the generated file to your response.
If you have any further questions or need additional assistance, please don’t hesitate to contact us.
Kent Russel P.
KentRusselP_Intel
Hi Raifart,
I just wanted to follow up and check if you’ve had a chance to review the information I shared previously. Your feedback is important, and I’d appreciate it if you could share your thoughts at your earliest convenience.
If you have any questions or need further clarification, please don’t hesitate to reach out.
Kent Russel P.
Raifart
Hello, I just now found the time, it seems to me that it is somehow difficult to deal with what you have described, but I will try, I will remind you that I have already written (created a topic) and it seemed that the problem went away with the new drivers, and now you offer me to install the old driver!?
Raifart
Besides, I couldn't find the 32.0.101.8132 driver.
I've never used DDU before. Doesn't the built-in utility do the job? I don't change graphics cards!
Added an SSU report.
KentRusselP_Intel
Hi Raifart,
Thanks for getting back to us. Could you please confirm if you've already tried the latest driver version 32.0.101.8247 (WHQL Certified)? If not, please install it and share a CapFrameX log of at least 300 seconds, making sure no overclocking is applied during the test.
If the issue still happens with the latest driver, please try using driver version 32.0.101.8132 instead. Also, send us a CapFrameX log using that older driver, along with an SSU report. This will help us figure out whether the problem is related to the driver version.
Before installing either driver, we recommend using Display Driver Uninstaller (DDU) to clean up the previous installation. Here's a helpful guide: How to Use the Display Driver Uninstaller (DDU) to Uninstall a...
If you have any questions or need help with any of the steps, feel free to reach out.
Kent Russel P.
KentRusselP_Intel
Hi Raifart,
Kent Russel P.
KentRusselP_Intel
Hi Raifart,
I hope you're doing well. As I haven’t received a response, I will proceed to close this inquiry. Should you require further assistance or have additional questions, please feel free to submit a new request. Kindly note that this thread will no longer be monitored once closed.
Kent Russel P.
