Intel® Arc™ Discrete Graphics
3633 Discussions
Unbelievably bad performance on 2D Unity game
masterofp
This (LOK Digital) and other Unity games, and games generally from Steam, have terrible performance on ultrawide monitor (5120x1440) with around 17 FPS. Even when I change the rendered resolution and go full screen.
To compare when I run Hitman 3 on same resolution with ultra settings, I get around 60. With XeSS enabled, around 80.
Mike_Intel
Hello masterofp,
  1. What is the exact model of your Graphics controller?
  2. What is the model of your processor?
  3. Was it working fine before?
  4. Did you change any settings before the issue started?
  5. What are the troubleshooting steps that you tried?
Michael L.
masterofp
1. It was Asrock B580 Steel Legend
2. AMD Ryzen 9 5950X, on X570 motherboard.
3. Yes, on RTX 3060 it was working fine.
4. No setting changes, resize bar stayed enabled when replacing RTX with B580.
5. Tried DDU in safe mode, reinstalled drivers. The game works fine when resolution is changed to a lower one (3040x1080) and game is ran in window.
6. I have returned this GPU back to the store and gone back to RTX 3060 Ti this time, so I don't need any further support.
Mike_Intel
Hello masterofp,
Thank you for for the update.
Since you already returned the unit and we cannot gather more details to investigate the issue and document the root cause, I need to close this inquiry.
Michael L.
