Intel® Arc™ Discrete Graphics
3479 Discussions
When a computer with a B580 graphics card is turned on after being in sleep mode, the screen display
你真的无敌了
Every time the computer wakes up from hibernation or sleep, the screen gets damaged. However, it will disappear immediately if I restart it right away.
Mike_Intel
Hello 你真的无敌了,
  1. Was it working fine before?
  2. What was the last change in the system before the issue started?
  3. What are the troubleshooting steps that you tried so far?
  4. Did you try to update the BIOS and Graphics driver?
  5. Please help generate the SSU logs of your system for me to review the hardware and installed drivers. Kindly refer to the link below for the steps on how to generate the logs:
Michael L.
你真的无敌了
I found the problem. It was just because the VRAM was changed from 19Gbps to 20Gbps. The issue disappeared after I restored it to the default setting. Thank you. I don't need help anymore.
Mike_Intel
Hello 你真的无敌了,
Thank you for the update.
Since the issue is now fixed, I need to close this inquiry.
Michael L.
