Can consumers buy the ARC Pro B60 cards from retail stores? Or is it only for project Battlematrix and system integrators?
What is the price for the 24GB ARC Pro B60?
What is the price for the 48GB ARC Pro B60?
Hi prometheus,
Thank you for reaching out to the Intel Community Forum.
Consumer retail availability for the Arc Pro B60 has not been planned. Intel is currently evaluating additional channel availability based on the readiness of the phased software rollout. The Arc Pro B60 add-in boards will only be available from AIB partners, and the target market is primarily workstation-class AI inference, not direct consumer retail.
The pricing for the Arc Pro B60 add-in cards will vary depending on system integrators and resellers. It is expected to start around $500 and may increase based on additional hardware and form-factor features.
Archie D.
ok, thank you.
Hoping Arc Pro B60 will be released to consumers. I was interested in using it for AI inference in my workstation PC for App development and AI research.
Hi prometheus,
Thank you for the update. I will check this and will get back to you once an update is available. Thank you for your patience and understanding.
Archie D.
Hi prometheus,
Thank you for your valuable input! I appreciate your engagement and encourage you to check our Intel Newsroom for the latest updates and news. For more detailed information on our product plans, you might find our "Where to Find Intel® Product Roadmaps" article helpful. It provides insights into upcoming technologies and developments.
Archie D.
Kudos are disabled. I'm also interested in getting one or two of the Arc B60 Dual cards for running LLMs locally.
I hope Intel is not about to miss the potential they have in hand with these cards and underestimate private customer needs these days.
Are you accessing from a smartphone? I have seen some issues with placement of button region (I just poked around until it went through). It's better to access site from PC - and remember you need to be logged on to give kudos.
(Kudos dont work neither PC nor Mobile. - I don't care but it doesn't show Intel what matters.)
