Intel® Arc™ Discrete Graphics
3623 Discussions
adaptive vsync
ALAK
Hi mate i want ask what is adaptive vsync  and what do exactly
ALAK
and how disable AdaptiveVsyncEnable on regedit the default value its 1
VonM_Intel
Hi, ALAK,
Thank you for posting in our Intel communities.
VESA Adaptive Sync is one of several different standards to achieve Variable Refresh Rate (VRR). Intel Arc A-Series GPUs are compatible with VESA Adaptive Sync.
In a nutshell VRR adjust its refresh rate based on the frame rate of the video source, including game content, to eliminate the stuttering or tearing of the image and enable smooth display of the source.
In Intel Arc Control you can also set different options for frame-delivery technologies. Check this link for more information.
As for your question on disabling 'AdaptiveVsyncEnable' in Regedit - as policy we do not support modifying the Windows Registry as this can lead to system instability or catastrophic results.
You can enable or disable VRR using Intel Arc Control and also via Windows -> Settings -> System -> Display -> Graphics.
Von M.
ALAK
The adaptive sync is  not like adaptive vsync its another option the adaptive vsync is smart sync on intel command center so i dont need install command center to disable it just tell me how disable this option  ask the dev on your company
VonM_Intel
Hi, ALAK.
Thank you for your response. We will do further research on this matter and post the response on this thread once available.
Von M.
VonM_Intel
Hi, ALAK.
I appreciate your interest in customizing your settings through the registry. However, in line with Intel's guidelines, we typically do not support alterations to the Windows registry. Such modifications carry a risk of causing system errors and potential instability. Given that this matter pertains to the Windows operating system, we suggest consulting Microsoft Support for more specialized guidance.
For adjusting VRR settings in Windows, navigate to Display -> General -> Variable Refresh Rate.
For configuring Smooth/Smart sync, you can go to: Settings -> Global Game Settings -> Frame Delivery -> Tearing Mitigation Modes.
Moreover, both settings can be turned off in the Intel Arc Control application.
Von M.
VonM_Intel
Hi, ALAK.
I trust you're doing well.
I have not heard back from you, we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
