Intel® Arc™ Discrete Graphics
3644 Discussions
graphis management
JulienSorel
I have intel UHD 770, but I am not able to make adjustments to my video picture setting through the Intel management software. Dell support says that is the way it is supposed to be, and I must make adjustments through video player. I don't believe that. Does anyone have a different experience. (This is new computer. I have used Nvidia, and that is how I would expect any graphics card to work.)
Hugo_Intel
Hello JulienSorel
Thank you for posting on the Intel® ARC™ Graphics Communities. I am sorry to hear that you are experiencing issues to modify video playback settings on your Intel® UHD Graphics 770.
The settings that you can modify through Intel® Graphics Command Center are outlined in the following article:
How to Adjust Video Settings Using the Intel® Graphics Command Center
You can find instructions to install Intel® Graphics Command Center in the following article:
How to Install the Intel® Graphics Command Center From the Microsoft Store
Hugo O.
JulienSorel
I know how to do that. The problem is that when I do it, nothing changes. The picture stays the same no matter what I do. It is getting worse, and I think the graphics card is defective. Your answer helps because it contradicts the answer from Dell customer support, which I didn't believe in the first place.
Hugo_Intel
Hello JulienSorel
I hope you are doing fine.
Were you able to check the previous post?
Let us know if you still need assistance.
Best regards,
Hugo O.
Intel Customer Support Technician.
JulienSorel
I think that I need a new graphics card. The technician said everything tested out. But if I must believe the test or my eyes, I believe my eyes.
Hugo_Intel
Hello JulienSorel
Thank you for letting us know. In this case, the issue might be related to a limitation by the manufacturer of the system, however, we would like to take a further look at the issue. Please share with us the following information:
Hugo O.
Hugo_Intel
Hello JulienSorel
Please share with us the information requested in my previous post in order to further assist you with this issue.
Hugo O.
JulienSorel
It is a lot of hassle considering that I have no warranty with Intel. My question was about HOW the video card is SUPPOSED to work. You have not answered my question. I will continue to work with Dell to solve the problem.
Hugo_Intel
Hello JulienSorel
Thank you for your feedback. The color settings should impact what you see on the screen unless there is a manufacturer's limitation, this is why we shared instructions on how to do it in my first post.
I understand that you will continue to work with your manufacturer, so in this case, we will close this thread, however, if you have further questions do not hesitate in opening a new topic.
Hugo O.
