fps in minecraft java are unstable and when I use another api like Vulkan the performance is not unstable and even increases.
Hello @TheRitrax
I am sorry to hear that you have problems with Intel® Arc™ Graphics Family, and I’ll be more than happy to help you.
Please answer the following:
· Was the game working before?
· Have you tried using a different driver version?
· Game version.
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the Report for Intel® Intel Graphics Command Center
Jose B.
Hello, sorry for the delay in my reply
The game did work before
no
The version of minecraft java game is 1.20.1
and the mod I used to use Vulkan was Vulkan Renderer
Hello TheRitrax
We hope you are doing fine.
Jose B.
Hello TheRitrax
Thank you for your response.
Please keep in mind that it is important for us to get all the information we require in order to provide a better assistance.
Do not forget the reports from Intel® System Support Utility for Windows and Intel® Intel Graphics Command Center
Jose B.
Hello TheRitrax
Were you able to generate both reports?
Jose B.
Hello TheRitrax
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
