tengo el emulador de play station 3, necesito una tarjeta grafica vulkan, cual seria la ideal para que funcione bien el emulador?
Hello Dan_34,
Thank you for posting on the Intel® communities. I understand you need a recommendation on which GPU will perform better with your emulator.
In this case, since playing emulated games might infringe on the intellectual property of other companies, Intel will not support issues or inquiries on emulated games.
I recommend you check with the emulator developer to confirm which GPU they recommend for their tool.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
