Intel® Arc™ Discrete Graphics
3508 Discussions
A750 driver crash / no output
curles
Basic info:
A750 founder's edition
Ryzen 9 3900X
motherboard X470
ReBAR enabled
Win10 22H2 x64
Description:
After I updated from 31.0.101.4369 to 31.0.101.4502 (I checked "clean install" during the upgrade), I have started experiencing random problems that manifest in the following ways:
- occasionally on boot/restart, BIOS will show a message that the hardware is unsupported and it has turned CSM on
- in windows, while doing nothing notable in particular (not a high load), the screen will go black (monitor stops getting signal - not just a black screen). just the display has stopped working, because i can still interact with the system via keyboard, so i am able to restart the computer via a run command and the display will come back on after restart
- the BIOS error appears to follow on next restart after the signal cuts out, but i haven't seen enough to identify if it always follows yet
I am currently unable to revert back to the previous driver version or download anything from intel's website because it looks like intel's download site SSL certificate has just expired.
Hugo_Intel
Hello curles
Thank you for posting on the Intel® ARC™ Graphics Communites. I am sorry you are experiencing display issues and errors when booting your system with Intel® Arc™ A750 graphics.
As a first recommendation, please try reinstalling driver 31.0.101.4502 using Display Driver Uninstaller and check if the issue persists.
Also, if possible, please test if the issue happens when using a different monitor and cables.
If the issue still happens, please share with us the following reports:
Intel® System Support Utility
Report for Intel® Graphics Drivers (Only IGCC report)
Hugo O.
Hugo_Intel
Hello curles
Hugo O.
Hugo_Intel
Hello curles
I hope you are doing fine.
Hugo O.
curles
Hi Hugo,
Thanks for following up. I have followed your last post and am currently monitoring the results. Given the unpredictable nature of the issue, I won't know if it's fixed until after an extended period of time.
I will report back if I observe the same or different error.
Thanks again!
Hugo_Intel
Hello curles
We wanted to check back on this thread since you indicated you wanted some time to test if the issue is fixed. Please let us know if you happen to experience crashes again or if you need more time for testing purposes.
Hugo O.
curles
Hi Hugo, I have not encountered it again so far, but i have not yet had the opportunity to use it with heavy loads yet. I will follow up if it reoccurs. Thanks!
Hugo_Intel
Hello curles
Thank you for letting us know. Since you need more time for testing purposes we will continue to monitor the thread for a few more days. Let us know the results once you have the chance to test the system.
Hugo O.
Hugo_Intel
Hello curles
I wanted to follow up on this issue and check if you had the time to test your system and if this issue reocurred or if it can be considered resolved. Pease let us know.
Hugo O.
Hugo_Intel
Hello curles
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
curles
Hi Hugo,
I can report that I have not seen the same issue so far and have put the GPU through various use cases now. I have since upgraded through to 101.4577 which is what I am currently on.
If it comes back up in the future I will create a new post.
Thank you very much for your help!
