Intel® Arc™ Discrete Graphics
4397 Discussions
ARC Control panel bugs + OpenGL issues.
Robotsmasher0
HI,
#1: ARC Control panel will show the current driver version for the integrated HD P630 video instead of the ARC A750 driver version. You should probably fix the ARC Control Panel to show the ARC driver version instead of the HD P630 version.
#2: Please spend a bit more time refining the OpenGL drivers. I play BAR (Beyond All Reason) which uses OpenGL. Good news is the ARC drivers work. Bad news is the bump mapping and water shaders don't seem to function correctly.
Cheers!
Hugo_Intel
Hello Robotsmasher0
Thank you for posting on the Intel® ARC™ Graphics Communites. I am sorry you are experiencing discrepancies in the information being displayed on the Intel® Arc™ Control Software. Please share with us the following information:
In regard, to the other issue that you mentioned about OpenGL and the game Beyond All Reason, please open a new thread in order to keep one issue per thread and to prevent confusion in the troubleshooting steps as well as for other community members that might be experiencing similar issues.
Hugo O.
Hugo_Intel
Hello Robotsmasher0
I hope you are doing fine.
Hugo O.
Hugo_Intel
Hello Robotsmasher0
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
