Intel® Arc™ Discrete Graphics
3557 Discussions
AYUDA NO PUEDO ARREGLAR ESTO
HM7
LA CONFIGURACION ACTUAL DEL SISTEMA NO ES COMPATIBLE CON INTEL GRAPHICS SOFTWARE.
Habra solucion para esto disculpen comunidad.
n_scott_pearson
More information is needed.
Please download and run the Intel System Support Utility for Windows. When you start the utility, select Everything and then click on Scan. Once it completes the scan process, click on Next and then Save. Pick a name for the text file to create and click on Save to create it. You can then close the app. Finally, open a response post here and then, using the Drag and drop here or browse files to attach dialog (below the edit box for the body of your response post), upload and attach this text file to the response post.
Lulusha
Can you help me? I have a same issue
