After installing the latest Windows update, I noticed that my Ultrawide monitor's resolution is no longer being supported properly. Prior to the update, the monitor displayed content at its native resolution without any issues. However, following the update, the resolution options seem limited, and the display quality has notably decreased. This has affected both my work efficiency and the visual experience while using my computer.
Steps Taken: I have attempted to update graphics drivers, adjust display settings, and reboot the system, but the issue persists.
Dell Vostro 3500
Report Date: Tuesday, 29 August 2023
Report Time [hh:mm:ss]: 10:45:55 PM
Operating System: Microsoft Windows 11 Pro 10.0.22621
IGCC Version: 1.100.5180.0
Language: en-US
Physical Memory: 7.73 GB
Current Resolution: 1920x1080
Processor: 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz
Processor Speed: 2995 MHz
GFX Driver Name: Intel® UHD Graphics
Shader Version: 5.1
OpenCL* Version: 3.0
* Microsoft DirectX* *
Runtime Version: 12
Hardware-Supported Version: 12
Vendor ID: 8086
Device ID: 9A78
Device Revision: 01
GFX Driver Version: 31.0.101.4502
Dedicated RAM: 128 MB
Shared RAM: 4 GB
Max Supported Displays: 4
GFX Vulcan: 1.3.250
GFX GOP: 17.0.1042
* Devices connected to the Graphics Accelerator *
Active Displays: 2
* Digital Display 1 *
Display Name: Built-In Display
Display Type: Digital
Serial Number: -
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: DisplayPort
Maximum Image Size
Horizontal - 13.39 inches
Vertical - 7.48 inches
Supported Modes
1920 x 1080 (48p Hz)
1920 x 1080 (60p Hz)
Power Management Support
* Digital Display 2 *
Display Name: LG HDR WFHD
Serial Number: -
Gamma: 2.2
Connector Type: HDMI
Maximum Image Size
Horizontal - 31.5 inches
Vertical - 13.39 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 480 (60p Hz)
720 x 576 (50p Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (60p Hz)
1152 x 870 (75p Hz)
1280 x 720 (50p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1280 x 1024 (60p Hz)
1280 x 1024 (75p Hz)
1600 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (75p Hz)
2560 x 1080 (50p Hz)
2560 x 1080 (60p Hz)
2560 x 1080 (75p Hz)
2560 x 1440 (60p Hz)
3840 x 2160 (24p Hz, 4K)
3840 x 2160 (25p Hz, 4K)
3840 x 2160 (30p Hz, 4K)
Standby Mode Supported
Suspend Mode Supported
Active Off Mode Supported
連結已複製
Hello R_Mendis,
Thank you for posting on the Intel
Just to have a better idea of the issue, please answer the questions below:
- What port are you using to connect the display?
- I see you mentioned the Display Name is LG HDR WFHD, but what is the make and model?
- I noticed your display is running at 1920x1080, what is the resolution you want to use?
Andres P.
Hi Andres P.
Thank you for offering your assistance.
Laptop Model: Dell Vostro 3500 (i3).
- I'm using the HDMI port
- Model LG 29WN600-W 29-inch 21:9 UltraWide WFHD IPS HDR10 Monitor
- My monitor supports 2560 x 1080 (21:9) resolution, but after a latest Windows update, it only displays 1920x1080 (16:9), and it now looks like the image below.
(For your reference, I've already asked about this in the Microsoft community, but I have not received an update or solution yet. answers.microsoft. )
R_Mendis
Hello R_Mendis,
Thank you for answering all the questions it has been really helpful.
Based on the manual and specifications of the Dell Vostro 3500, it says that the maximum resolution supported by HDMI port of the laptop is 1920x1080 @60Hz (24 bit). For more information, you can access on Vostro 3500 Setup and specifications guide.
Let me know if you have further questions.
Andres P.
Hello R_Mendis,
Were you able to check the previous post? Remember that based on the manual and specifications of the Dell Vostro 3500, it says that the maximum resolution supported by HDMI port of the laptop is 1920x1080 @60Hz (24 bit).
Andres P.
Hello R_Mendis,
Thank you for your response.
Happy to hear that the issue is solved, I recommend you to contact Dell, because as per their specifications, as I mentioned before, the HDMI port of the laptop is 1920x1080 @60Hz (24 bit), so with them, you can verify if using the resolution 3840 x 2160 (30p Hz, 4K) is not going to damage the computer as is working above the specifications.
For now, we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
