Intel® Arc™ Discrete Graphics
Albion online fix
ALAK
Hi mate i have problem on albion online  if i set the game on fuullsecreen the game go black screen
ACarmona_Intel
Hello ALAK,
Please answer the following questions and follow some instructions below to help us further isolate the issue and come up with a solution:
  • When did the issue start? Did the game work fine before?
  • Have you made any changes to the system that might have caused the issue?
  • Have you already updated your OS to the latest version? If not, please make sure that it is up-to-date.
  • What happens in either "Window" or "Borderless Full screen Window" modes in the game?
  • Please generate an SSU report to help me further analyze important details on your system, such as the OS build number, graphics driver version, errors logged in the system, etc. To generate the SSU report, please refer to the article How to Get the Intel® System Support Utility Logs on Windows. Please send us the generated SSU.txt file.
I am looking forward to hearing from you.
Thank you very much!
Carmona A.
ALAK
1) yes it was work before
2)yes i disable full screen optimazation
3)my os was windows 10 22h2 but i update to windoes 11 22h2 because windows 23h2 give error tell me enabe razer bar to install arc controle but i enabled
3)its work on window mode or broderless full screen mode the problem ony on full screen exlusive
4)i send it  soon because now i am not on home
ALAK
System Information
      Time of this report: 2/29/2024, 15:08:04
             Machine name: DESKTOP-8Q6UBUS
               Machine Id: {2088A021-DA96-4323-A2E7-E8AE0FB34628}
         Operating System: Windows 11 Home 64-bit (10.0, Build 22621) (22621.ni_release.220506-1250)
                 Language: English (Regional Setting: English)
      System Manufacturer: Micro-Star International Co., Ltd
             System Model: MS-7B86
                     BIOS: H.I0 (type: UEFI)
                Processor: AMD Ryzen 5 5600X 6-Core Processor              (6 CPUs), ~4.2GHz
                   Memory: 24576MB RAM
      Available OS Memory: 24502MB RAM
                Page File: 5102MB used, 19399MB available
              Windows Dir: C:\Windows
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: 96 DPI (100 percent)
       System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
 DirectX Database Version: 1.4.9
           DxDiag Version: 10.00.22621.0001 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
           Card name: Intel(R) Arc(TM) A770 Graphics
        Manufacturer: Intel Corporation
           Chip type: Intel(R) Arc(TM) A770 Graphics Family
            DAC type: Internal
         Device Type: Full Device (POST)
          Device Key: Enum\PCI\VEN_8086&DEV_56A0&SUBSYS_60011849&REV_08
       Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
 Device Problem Code: No Problem
 Driver Problem Code: Unknown
      Display Memory: 20346 MB
    Dedicated Memory: 8096 MB
       Shared Memory: 12250 MB
        Current Mode: 1920 x 1080 (32 bit) (144Hz)
         HDR Support: Not Supported
    Display Topology: Internal
 Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
     Color Primaries: Red(0.639648,0.330078), Green(0.299805,0.599609), Blue(0.149414,0.059570), White Point(0.312500,0.329102)
   Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
        Monitor Name: Generic PnP Monitor
       Monitor Model: ZOWIE XL LCD
          Monitor Id: BNQ7F33
         Native Mode: 1920 x 1080(p) (60.000Hz)
         Output Type: Displayport External
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
      Advanced Color: Not Supported
         Driver Name: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd12umd64.dll
 Driver File Version: 31.00.0101.5333 (English)
      Driver Version: 31.0.101.5333
         DDI Version: 12
      Feature Levels: 12_2,12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
        Driver Model: WDDM 3.1
 Hardware Scheduling: DriverSupportState:AlwaysOff Enabled:False
         Displayable: Not Supported
 Graphics Preemption: Triangle
  Compute Preemption: Thread group
            Miracast: Not Supported
      Detachable GPU: No
 Hybrid Graphics GPU: Discrete
      Power P-states: Not Supported
      Virtualization: Paravirtualization
          Block List: DISABLE_HWSCH
  Catalog Attributes: Universal:False Declarative:True
   Driver Attributes: Final Retail
    Driver Date/Size: 2/21/2024 1:00:00 AM, 2498304 bytes
         WHQL Logo'd: Yes
     WHQL Date Stamp: Unknown
   Device Identifier: {D7B78E66-15E0-11CF-2C6F-6440A7C2D235}
           Vendor ID: 0x8086
           Device ID: 0x56A0
           SubSys ID: 0x60011849
         Revision ID: 0x0008
  Driver Strong Name: oem0.inf:5f63e534827817bd:iDG2_Client_FWU_w10_DS:31.0.101.5333:PCI\VEN_8086&DEV_56A0&SUBSYS_60011849
      Rank Of Driver: 00CF0001
         Video Accel: Unknown
         DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  {E07EC519-E651-4CD6-AC84-1370CCEEC851}  {BCC5DB6D-A2B6-4AF0-ACE4-ADB1F787BC89}  DXVA2_ModeVC1_D2010  DXVA2_ModeVC1_IDCT  DXVA2_ModeWMV9_IDCT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeH264_VLD_Multiview_NoFGT  {C528916C-C0AF-4645-8CB2-372B6D4ADC2A}  {07CFAFFB-5A2E-4B99-B62A-E4CA53B6D5AA}  {91CD2D6E-897B-4FA1-B0D7-51DC88010E0A}  {8C56EB1E-2B47-466F-8D33-7DBCD63F3DF2}  DXVA2_ModeHEVC_VLD_Main  {75FC75F7-C589-4A07-A25B-72E03B0383B3}  DXVA2_ModeHEVC_VLD_Main10  {9CC55490-E37C-4932-8684-4920F9F6409C}  {0BAC4FE5-1532-4429-A854-F84DE04953DB}  {4008018F-F537-4B36-98CF-61AF8A2C1A33}  {0DABEFFA-4458-4602-BC03-0795659D617C}  {1A72925F-0C2C-4F15-96FB-B17D1473603F}  {55BCAC81-F311-4093-A7D0-1CBC0B849BEE}  {9798634D-FE9D-48E5-B4DA-DBEC45B3DF01}  {E484DCB8-CAC9-4859-99F5-5C0D45069089}  {41A5AF96-E415-4B0C-9D03-907858E23E78}  {6A6A81BA-912A-485D-B57F-CCD2D37B8D94}  {E4E3CF5B-97D2-4658-AACB-366E3EE2CEEE}  {FD9D9559-0FD3-4917-A9A7-07E714EE9EF9}  {8FF8A3AA-C456-4132-B6EF-69D9DD72571D}  {C23DD857-874B-423C-B6E0-82CEAA9B118A}  {5B08E35D-0C66-4C51-A6F1-89D00CB2C197}  {0E4BC693-5D2C-4936-B125-AEFE32B16D8A}  {2F08B5B1-DBC2-4D48-883A-4E7B8174CFF6}  {5467807A-295D-445D-BD2E-CBA8C2457C3D}  {AE0D4E15-2360-40A8-BF82-028E6A0DD827}  DXVA2_ModeVP9_VLD_Profile0  DXVA2_ModeVP9_VLD_10bit_Profile2  {76988A52-DF13-419A-8E64-FFCF4A336CF5}  {68A21C7B-D58F-4E74-9993-E4B8172B19A0}  {80A3A7BD-89D8-4497-A2B8-2126AF7E6EB8}  {1D5C4D76-B55A-4430-904C-3383A7AE3B16}  {A7F759DD-5F54-4D7F-8291-42E883C546FE}  {F34FA92F-DC79-474C-B0DB-B7BD4522DF77}  {B8BE4CCB-CF53-46BA-8D59-D6B8A6DA5D2A}  {CA44AFC5-E1D0-42E6-9154-B127186D4D40}  {F9A16190-3FB4-4DC5-9846-C8751F83D6D7}  {49761BEC-4B63-4349-A5FF-87FFDF088466}  {97688186-56A8-4094-B543-FC9DAAA49F4B}  {1424D4DC-7CF5-4BB1-9CD7-B63717A72A6B}  {464BDB3C-91C4-4E9B-896F-225496AC4ED6}  {9B31316B-F204-455D-8A8C-9345DCA77C01}  {AFE4285C-AB63-4B2D-8278-E6BAACEA2CE9}  {277DE9C5-ED83-48DD-AB8F-AC2D24B22943}  {04C5BA10-4E9A-4B8E-8DBF-4F4B48AFA27C}  {0ACEF8BC-285F-415D-AB22-7BF2527A3D2E}  {24D19FCA-C5A2-4B8E-9F93-F8F6EF15C890}  {353ACA91-D945-4C13-AE7E-469060FAC8D8}  {B8B28E0C-ECAB-4217-8C82-EAAA9755AAF0}  {8732ECFD-9747-4897-B42A-E534F9FF2B7A}  {580DA148-E4BF-49B1-943B-4214AB05A6FF}  {CEE393AB-1030-4F7B-8DBC-55629C72F17E}  {87B2AE39-C9A5-4C53-86B8-A52D7EDBA488}  {10E19AC8-BF39-4443-BEC3-1B0CBFE4C7AA}  {2DEC00C7-21EE-4BF8-8F0E-773F11F126A2}  {C35153A0-23C0-4A81-B3BB-6A1326F2B76B}  {A33FD0EC-A9D3-4C21-9276-C241CC90F6C7}  {310E59D2-7EA4-47BB-B319-500E78855336}  {8090A09C-6FC5-48EF-9F40-65BF37F7ACC4}  {0EEA5B11-88C0-4A9F-81AC-B10FD66B22EA}  {50925B7B-E931-4978-A12A-586630F095F9}  {3325F221-DB34-47B6-8308-46095447114E}
      Deinterlace Caps: n/a
        D3D9 Overlay: Not Supported
             DXVA-HD: Supported
        DDraw Status: Disabled
          D3D Status: D3D v7 or earlier apps disabled, D3D v8 or later apps enabled
          AGP Status: Not Available
       MPO MaxPlanes: 3
            MPO Caps: ROTATION,HORIZONTAL_FLIP,RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)
         MPO Stretch: 21.000X - 0.334X
     MPO Media Hints: colorspace Conversion
         MPO Formats: NV12,YUY2,R16G16B16A16_FLOAT,R10G10B10A2_UNORM,R8G8B8A8_UNORM,B8G8R8A8_UNORM
    PanelFitter Caps: ROTATION,HORIZONTAL_FLIP,RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)
 PanelFitter Stretch: 21.000X - 0.334X
   Component Drivers:
             Driver Name: Unknown
          Driver Version: Unknown
             Driver Date: Unknown
         Driver Provider: Unknown
      Catalog Attributes: N/A
Sound Devices
            Description: Speakers (High Definition Audio Device)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1462CB86&REV_1003
        Manufacturer ID: N/A
             Product ID: N/A
                   Type: N/A
            Driver Name: HdAudio.sys
         Driver Version: 10.0.22621.4 (English)
            WHQL Logo'd: Yes
          Date and Size: 6/1/2022 1:00:00 AM, 528384 bytes
            Other Files:
        Driver Provider: Microsoft
         HW Accel Level: Emulation Only
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
            Description: Microphone (High Definition Audio Device)
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x1
           Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 0
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: G203 LIGHTSYNC Gaming Mouse
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC092
        FF Driver: n/a
      Device Name: Gaming Keyboard G213
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC336
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (USB 3.0)
| Vendor/Product ID: 0x1022, 0x149C
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 5/7/2022 06:19:25, 722256 bytes
+-+ G213
| | Matching Device ID: USB\VID_046D&PID_C336
| | Lower Filters: vhf, logi_lamparray
| | Service: usbccgp
| | Driver: logi_lamparray.sys, 2/21/2024 15:39:36, 89072 bytes
| | Driver: logi_lamparray_service.exe, 2/21/2024 15:39:36, 9887216 bytes
| | Driver: usbccgp.sys, 9/25/2022 03:32:44, 226648 bytes
| +-+ USB Input Device
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 5/7/2022 06:19:25, 77824 bytes
| | | Driver: hidclass.sys, 5/7/2022 06:19:25, 278528 bytes
| | | Driver: hidparse.sys, 5/7/2022 06:19:25, 90112 bytes
| | +-+ HID Keyboard Device
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 5/7/2022 06:19:25, 73728 bytes
| | | | Driver: kbdclass.sys, 5/7/2022 06:19:25, 95576 bytes
| | | Service: HidUsb
| | | | Service: kbdhid
+-+ G203 LIGHTSYNC
| | Matching Device ID: USB\VID_046D&PID_C092
| | Service: usbccgp
| | | Service: HidUsb
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 5/7/2022 06:19:25, 69632 bytes
| | | | Driver: mouclass.sys, 5/7/2022 06:19:25, 95592 bytes
| | | Service: HidUsb
| | | | Service: kbdhid
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 142.9 GB
Total Space: 228.8 GB
File System: NTFS
      Model: CT240BX500SSD1
System Devices
     Name: AMD USB 3.10 eXtensible Host Controller - 1.10 (Microsoft)
Device ID: PCI\VEN_1022&DEV_149C&SUBSYS_7B861462&REV_00\4&8F327EB&0&0341
   Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.22621.0317 (English), 9/25/2022 03:32:44, 677232 bytes
   Driver: C:\Windows\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.22621.0317 (English), 9/25/2022 03:32:44, 166704 bytes
     Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1447&SUBSYS_00000000&REV_00\3&11583659&0&C7
   Driver: n/a
     Name: Intel(R) Arc(TM) A770 Graphics
Device ID: PCI\VEN_8086&DEV_56A0&SUBSYS_60011849&REV_08\6&29DCCDC3&0&00080019
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdkmdnd64.sys, 31.00.0101.5333 (English), 2/23/2024 19:13:38, 54555088 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\iglhxsnd64.vp, 2/23/2024 18:28:52, 5354 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd10iumd64.dll, 31.00.0101.5333 (English), 2/23/2024 19:14:32, 4179520 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd11dxva64.dll, 31.00.0101.5333 (English), 2/23/2024 19:15:28, 4207048 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd12dxva64.dll, 31.00.0101.5333 (English), 2/23/2024 19:15:34, 3275264 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igddxvacommon64.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:16, 20739688 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\media_bin_64.dll, 31.00.0101.5333 (English), 2/23/2024 19:21:04, 30840848 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd12umd64.dll, 31.00.0101.5333 (English), 2/23/2024 19:16:14, 1169448 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd10um64xe.dll, 31.00.0101.5333 (English), 2/23/2024 19:14:54, 25429984 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd10umt64xe.dll, 31.00.0101.5333 (English), 2/23/2024 19:15:18, 24932088 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd10mg64.dll, 31.00.0101.5333 (English), 2/23/2024 19:14:42, 2278400 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd12um64xel.dll, 31.00.0101.5333 (English), 2/23/2024 19:16:06, 21302112 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd12um64xeh.dll, 31.00.0101.5333 (English), 2/23/2024 19:16:00, 22684176 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdgmm64.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:28, 4493520 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igfxcmrt64.dll, 31.00.0101.5333 (English), 2/23/2024 19:18:04, 221536 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igfx11cmrt64.dll, 31.00.0101.5333 (English), 2/23/2024 19:18:02, 224680 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdumdim64.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:58, 2498304 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd9trinity32.dll, 31.00.0101.5333 (English), 2/23/2024 19:16:34, 23205280 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd9trinity64.dll, 31.00.0101.5333 (English), 2/23/2024 19:16:44, 24465072 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdail64.dll, 31.00.0101.5333 (English), 2/23/2024 19:13:24, 277056 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd9dxva64.dll, 31.00.0101.5333 (English), 2/23/2024 19:16:22, 22450400 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\iga64.dll, 31.00.0101.5333 (English), 2/23/2024 19:13:58, 3324192 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igc64.dll, 31.00.0101.5333 (English), 2/23/2024 19:14:16, 67517392 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\DnnlPlugin.dll, 0.01.0000.0000 (English), 2/23/2024 19:13:42, 19304272 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\XeFX.dll, 0.02.0267.0000 (English), 2/23/2024 19:22:38, 140584 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igxess.dll, 0.04.0267.0000 (English), 2/23/2024 19:18:52, 88133048 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\UniversalAdapter64.dll, 31.00.0101.5333 (English), 2/23/2024 19:22:34, 612136 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igmlsblob64xel.dll, 0.01.0053.0000 (English), 2/23/2024 19:18:18, 3065928 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igmlsblob64xeh.dll, 0.01.0053.0000 (English), 2/23/2024 19:18:12, 6942264 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\opencl-clang64.dll, 2.00.0009.0000 (English), 2/23/2024 19:22:16, 66983016 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdfcl64.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:26, 1145064 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdmd64.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:38, 19168536 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdml64.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:48, 3509664 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdde64.dll, 31.00.0101.5333 (English), 2/23/2024 19:16:58, 405944 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdinfo64.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:32, 165376 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdext64.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:24, 162304 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd10iumd32.dll, 31.00.0101.5333 (English), 2/23/2024 19:14:30, 4099368 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd11dxva32.dll, 31.00.0101.5333 (English), 2/23/2024 19:15:26, 3525128 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd12dxva32.dll, 31.00.0101.5333 (English), 2/23/2024 19:15:32, 2743160 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\media_bin_32.dll, 31.00.0101.5333 (English), 2/23/2024 19:20:38, 25415392 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igddxvacommon32.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:08, 19545392 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd12umd32.dll, 31.00.0101.5333 (English), 2/23/2024 19:16:12, 1135848 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd10um32xe.dll, 31.00.0101.5333 (English), 2/23/2024 19:14:44, 24289032 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd10umt32xe.dll, 31.00.0101.5333 (English), 2/23/2024 19:15:08, 23657792 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd10mg32.dll, 31.00.0101.5333 (English), 2/23/2024 19:14:36, 2189504 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd12um32xel.dll, 31.00.0101.5333 (English), 2/23/2024 19:15:48, 20475568 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd12um32xeh.dll, 31.00.0101.5333 (English), 2/23/2024 19:15:36, 21937896 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdgmm32.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:26, 3406360 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdumdim32.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:56, 2676968 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdail32.dll, 31.00.0101.5333 (English), 2/23/2024 19:13:22, 254016 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd9dxva32.dll, 31.00.0101.5333 (English), 2/23/2024 19:16:16, 21028888 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igfxcmrt32.dll, 31.00.0101.5333 (English), 2/23/2024 19:18:02, 179704 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igfx11cmrt32.dll, 31.00.0101.5333 (English), 2/23/2024 19:18:00, 180840 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\iga32.dll, 31.00.0101.5333 (English), 2/23/2024 19:13:56, 2681616 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igc32.dll, 31.00.0101.5333 (English), 2/23/2024 19:14:04, 59944536 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\UniversalAdapter32.dll, 31.00.0101.5333 (English), 2/23/2024 19:22:34, 520688 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\opencl-clang32.dll, 2.00.0009.0000 (English), 2/23/2024 19:22:06, 48930272 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdfcl32.dll, 31.00.0101.5333 (English), 2/23/2024 19:13:24, 1109056 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdmd32.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:34, 14151120 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdml32.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:46, 1043912 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdde32.dll, 31.00.0101.5333 (English), 2/23/2024 19:16:54, 335192 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdinfo32.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:32, 142080 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdext32.dll, 31.00.0101.5333 (English), 2/23/2024 19:17:22, 138024 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\libigd12dxva64.so, 2/23/2024 18:28:54, 25985912 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\libigd12umd64.so, 2/23/2024 18:28:54, 47296 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\libigd12um64xel.so, 2/23/2024 18:28:54, 7443736 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\libigd12um64xeh.so, 2/23/2024 18:28:54, 8217960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\libigc.so, 2/23/2024 18:28:52, 58164552 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\libLLVM-14.so, 2/23/2024 18:28:54, 34724952 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\libigdgmm_w.so.12, 2/23/2024 18:28:54, 2361992 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\libUniversalAdapter64.so, 2/23/2024 18:28:54, 587840 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\libigdfcl.so, 2/23/2024 18:28:54, 1043064 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\libopencl-clang.so.14, 2/23/2024 18:28:54, 164356216 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\libwsl_compute_helper.so, 2/23/2024 18:28:54, 550960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\UMED.dll, 31.00.0101.5333 (English), 2/23/2024 19:22:32, 148736 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\iglhxo64.vp, 2/23/2024 18:28:52, 42513 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\iglhxc64.vp, 2/23/2024 18:28:52, 44194 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\iglhxg64.vp, 2/23/2024 18:28:52, 43760 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\iglhxo64_dev.vp, 2/23/2024 18:28:52, 43143 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\iglhxc64_dev.vp, 2/23/2024 18:28:52, 43214 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\iglhxg64_dev.vp, 2/23/2024 18:28:52, 43732 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\iglhxa64.vp, 2/23/2024 18:28:52, 1125 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\iglhxa64.cpa, 2/23/2024 18:28:52, 1376256 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\cp_resources.bin, 2/23/2024 18:28:50, 2572396 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igxehpgicd64.dll, 31.00.0101.5333 (English), 2/23/2024 19:14:36, 20231232 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igxehpgicd32.dll, 31.00.0101.5333 (English), 2/23/2024 19:14:30, 16445400 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\OSSCOPYRIGHT.txt, 2/23/2024 18:28:54, 1372 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igvk64.dll, 31.00.0101.5333 (English), 2/23/2024 19:18:36, 22637224 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igvk64.json, 2/23/2024 18:28:52, 139 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\VulkanRT-EULA.txt, 2/23/2024 18:28:54, 4008 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igvk32.dll, 31.00.0101.5333 (English), 2/23/2024 19:18:28, 21670264 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igvk32.json, 2/23/2024 18:28:52, 139 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igvkMedia64.dll, 31.00.0101.5333 (English), 2/23/2024 19:18:48, 1316704 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igvkMedia32.dll, 31.00.0101.5333 (English), 2/23/2024 19:18:42, 1026256 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\vulkan-1-64.dll, 1.03.0261.0001 (English), 2/23/2024 19:16:18, 1442880 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\vulkaninfo-64.exe, 1.03.0261.0001 (English), 2/23/2024 19:16:20, 2095168 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\vulkan-1-32.dll, 1.03.0261.0001 (English), 2/23/2024 19:16:16, 1285184 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\vulkaninfo-32.exe, 1.03.0261.0001 (English), 2/23/2024 19:16:20, 1653312 bytes
   Driver: C:\Windows\SysWow64\vulkan-1.dll, 1.03.0261.0001 (English), 2/23/2024 19:16:16, 1285184 bytes
   Driver: C:\Windows\SysWow64\vulkaninfo.exe, 1.03.0261.0001 (English), 2/23/2024 19:16:20, 1653312 bytes
   Driver: C:\Windows\SysWow64\vulkan-1-999-0-0-0.dll, 1.03.0261.0001 (English), 2/23/2024 19:16:16, 1285184 bytes
   Driver: C:\Windows\SysWow64\vulkaninfo-1-999-0-0-0.exe, 1.03.0261.0001 (English), 2/23/2024 19:16:20, 1653312 bytes
   Driver: C:\Windows\system32\vulkan-1.dll, 1.03.0261.0001 (English), 2/23/2024 19:16:18, 1442880 bytes
   Driver: C:\Windows\system32\vulkaninfo.exe, 1.03.0261.0001 (English), 2/23/2024 19:16:20, 2095168 bytes
   Driver: C:\Windows\system32\vulkan-1-999-0-0-0.dll, 1.03.0261.0001 (English), 2/23/2024 19:16:18, 1442880 bytes
   Driver: C:\Windows\system32\vulkaninfo-1-999-0-0-0.exe, 1.03.0261.0001 (English), 2/23/2024 19:16:20, 2095168 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\Intel_OpenCL_ICD32.dll, 2.02.0008.0000 (English), 2/23/2024 19:15:26, 378432 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdrcl32.dll, 23.20.0101.5333 (English), 2/23/2024 19:13:48, 12626904 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\Intel_OpenCL_ICD64.dll, 2.02.0008.0000 (English), 2/23/2024 19:15:26, 515648 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\ze_loader.dll, 1.15.0008.0000 (English), 2/23/2024 19:16:32, 489944 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\ze_validation_layer.dll, 1.15.0008.0000 (English), 2/23/2024 19:16:42, 314840 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\ze_tracing_layer.dll, 1.15.0008.0000 (English), 2/23/2024 19:16:36, 518104 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\IntelControlLib.dll, 1.00.0184.0000 (English), 2/23/2024 19:19:24, 607424 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\IntelControlLib32.dll, 1.00.0184.0000 (English), 2/23/2024 19:19:26, 532976 bytes
   Driver: C:\Windows\SysWow64\IntelControlLib32.dll, 1.00.0184.0000 (English), 2/23/2024 19:19:26, 532976 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdrcl64.dll, 23.20.0101.5333 (English), 2/23/2024 19:13:54, 13992408 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\ze_intel_gpu64.dll, 1.03.28328.0000 (English), 2/23/2024 19:16:24, 19450432 bytes
   Driver: C:\Windows\SysWow64\OpenCL.dll, 3.00.0001.0000 (English), 9/25/2022 03:37:38, 76800 bytes
   Driver: C:\Windows\system32\OpenCL.dll, 3.00.0001.0000 (English), 9/25/2022 03:37:37, 118784 bytes
   Driver: C:\Windows\system32\ze_loader.dll, 1.15.0008.0000 (English), 2/23/2024 19:16:32, 489944 bytes
   Driver: C:\Windows\system32\ze_validation_layer.dll, 1.15.0008.0000 (English), 2/23/2024 19:16:42, 314840 bytes
   Driver: C:\Windows\system32\ze_tracing_layer.dll, 1.15.0008.0000 (English), 2/23/2024 19:16:36, 518104 bytes
   Driver: C:\Windows\system32\ControlLib.dll, 1.00.0184.0000 (English), 2/23/2024 19:13:40, 303152 bytes
   Driver: C:\Windows\SysWow64\ControlLib32.dll, 1.00.0184.0000 (English), 2/23/2024 19:13:42, 249920 bytes
   Driver: C:\Windows\SysWow64\libmfxhw32.dll, 23.06.0021.0536 (English), 2/23/2024 19:21:32, 705608 bytes
   Driver: C:\Windows\SysWow64\mfxplugin32_hw.dll, 23.06.0021.0536 (English), 2/23/2024 19:15:28, 20687936 bytes
   Driver: C:\Windows\system32\libmfxhw64.dll, 23.06.0021.0536 (English), 2/23/2024 19:21:34, 942696 bytes
   Driver: C:\Windows\system32\mfxplugin64_hw.dll, 23.06.0021.0536 (English), 2/23/2024 19:15:46, 27963864 bytes
   Driver: C:\Windows\system32\intel_gfx_api-x64.dll, 23.06.0021.0536 (English), 2/23/2024 19:19:28, 591376 bytes
   Driver: C:\Windows\system32\libvpl.dll, 2.10.0000.0000 (English), 2/23/2024 19:22:38, 750616 bytes
   Driver: C:\Windows\SysWow64\intel_gfx_api-x86.dll, 23.06.0021.0536 (English), 2/23/2024 19:19:36, 452896 bytes
   Driver: C:\Windows\SysWow64\libvpl.dll, 2.10.0000.0000 (English), 2/23/2024 19:22:36, 637336 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfxplugin64_hw.dll, 23.06.0021.0536 (English), 2/23/2024 19:15:46, 27963864 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfxplugin64_av1e_gacc.dll, 3.11.0005.0020 (English), 2/23/2024 19:21:28, 12444200 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\intel_gfx_api-x64.dll, 23.06.0021.0536 (English), 2/23/2024 19:19:28, 591376 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfxplugin32_hw.dll, 23.06.0021.0536 (English), 2/23/2024 19:15:28, 20687936 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfxplugin32_av1e_gacc.dll, 3.11.0005.0020 (English), 2/23/2024 19:21:24, 8537816 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\intel_gfx_api-x86.dll, 23.06.0021.0536 (English), 2/23/2024 19:19:36, 452896 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_h264ve_32.dll, 24.01.0016.4404 (English), 2/23/2024 19:21:52, 2351128 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_mjpgvd_32.dll, 24.01.0016.4404 (English), 2/23/2024 19:16:00, 2260032 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_h265ve_32.dll, 24.01.0016.4404 (English), 2/23/2024 19:21:54, 2365128 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_vp9ve_32.dll, 24.01.0016.4404 (English), 2/23/2024 19:21:58, 2359352 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_encrypt_32.dll, 24.01.0016.4404 (English), 2/23/2024 19:21:48, 2218832 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_av1hve_32.dll, 24.01.0016.4404 (English), 2/23/2024 19:21:34, 2364624 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\c_32.cpa, 2/23/2024 18:28:50, 1361159 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\cpa_32.vp, 2/23/2024 18:28:50, 1125 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\dev_32.vp, 2/23/2024 18:28:50, 57143 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\he_32.vp, 2/23/2024 18:28:52, 69653 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mj_32.vp, 2/23/2024 18:28:54, 65325 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\h265e_32.vp, 2/23/2024 18:28:52, 71197 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\vp9e_32.vp, 2/23/2024 18:28:54, 70820 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_av1hve_32.vp, 2/23/2024 18:28:54, 71153 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_h264ve_64.dll, 24.01.0016.4404 (English), 2/23/2024 19:21:54, 2880496 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_mjpgvd_64.dll, 24.01.0016.4404 (English), 2/23/2024 19:16:00, 2765376 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_h265ve_64.dll, 24.01.0016.4404 (English), 2/23/2024 19:21:56, 2898600 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_vp9ve_64.dll, 24.01.0016.4404 (English), 2/23/2024 19:21:58, 2895088 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_encrypt_64.dll, 24.01.0016.4404 (English), 2/23/2024 19:21:50, 2715800 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_av1hve_64.dll, 24.01.0016.4404 (English), 2/23/2024 19:21:36, 2898192 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\c_64.cpa, 2/23/2024 18:28:50, 1376256 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\cpa_64.vp, 2/23/2024 18:28:50, 1125 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\dev_64.vp, 2/23/2024 18:28:50, 56359 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\he_64.vp, 2/23/2024 18:28:52, 13307 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mj_64.vp, 2/23/2024 18:28:54, 12991 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\h265e_64.vp, 2/23/2024 18:28:52, 13715 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\vp9e_64.vp, 2/23/2024 18:28:54, 13726 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_av1hve_64.vp, 2/23/2024 18:28:54, 13699 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_av1ve_32.dll, 24.01.0016.4404 (English), 2/23/2024 19:21:38, 2364616 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_av1ve_32.vp, 2/23/2024 18:28:54, 71160 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_av1ve_64.dll, 24.01.0016.4404 (English), 2/23/2024 19:21:42, 2898704 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\mfx_mft_av1ve_64.vp, 2/23/2024 18:28:54, 13702 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\libmfx64-gen.dll, 24.01.0016.4404 (English), 2/23/2024 19:19:46, 23608896 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\libmfx32-gen.dll, 24.01.0016.4404 (English), 2/23/2024 19:19:38, 21943192 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\enctools32.dll, 24.01.0016.4404 (English), 2/23/2024 19:13:48, 7764544 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\enctools64.dll, 24.01.0016.4404 (English), 2/23/2024 19:13:52, 8893712 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\clangFEWrapper.dll, 1.00.0993.0000 (English), 2/23/2024 19:13:24, 40688944 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\clangFEWrapper32.dll, 1.00.0993.0000 (English), 2/23/2024 19:13:34, 31467200 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fw\dg2_gfx_fwupdate_SOC2.bin, 2/23/2024 18:28:56, 2101248 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fw\dg2_gfx_fwupdate_SOC1.bin, 2/23/2024 18:28:56, 2101248 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fw\dg2_gfx_fwupdate_SOC3.bin, 2/23/2024 18:28:56, 2101248 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\IntelGFXFWupdateTool.exe, 5.03.0013.0000 (English), 2/23/2024 19:15:18, 342080 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igsc.dll, 0.08.0011.0000 (English), 2/23/2024 19:18:24, 629656 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\oprom\dg2_c_oprom.rom, 2/23/2024 18:28:56, 1048576 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\oprom\dg2_d_intel_a770_oprom-data.rom, 2/23/2024 18:28:56, 1048576 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\oprom\dg2_d_intel_a750_oprom-data.rom, 2/23/2024 18:28:56, 1048576 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\oprom\dg2_d_intel_a750-gold_oprom-data.rom, 2/23/2024 18:28:56, 1048576 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\oprom\dg2_d_intel_a750-cr2_oprom-data.rom, 2/23/2024 18:28:56, 1048576 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\oprom\dg2_d_acer_predator-bifrost-a770_oprom-data.rom, 2/23/2024 18:28:56, 1048576 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\oprom\dg2_d_acer_predator-a380_oprom-data.rom, 2/23/2024 18:28:56, 1048576 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\oprom\dg2_d_asrock_challenger-a380_oprom-data.rom, 2/23/2024 18:28:56, 1048576 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\oprom\dg2_d_asrock_challenger-a750_oprom-data.rom, 2/23/2024 18:28:56, 1048576 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\oprom\dg2_d_asrock_phantom-gaming-a770_oprom-data.rom, 2/23/2024 18:28:56, 1048576 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\oprom\dg2_d_gunnir_photon-a380_oprom-data.rom, 2/23/2024 18:28:56, 1048576 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\oprom\dg2_d_gunnir_flux-a770_oprom-data.rom, 2/23/2024 18:28:56, 1048576 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\oprom\dg2_d_asus_dual-a380_oprom-data.rom, 2/23/2024 18:28:56, 1048576 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_intel_a770_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_intel_a750_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_intel_a750-gold_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_intel_a750-cr2_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_acer_predator-bifrost-a770_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_acer_predator-a380_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_asrock_challenger-a310_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_asrock_challenger-a380_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_asrock_challenger-a580_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_asrock_challenger-a750_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_asrock_phantom-gaming-a770_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_gunnir_photon-a380_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_gunnir_index-a380_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_gunnir_gu23a-a580_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_gunnir_photon-a750_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_gunnir_flux-a750_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_gunnir_photon-a770_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_gunnir_flux-a770_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_sparkle_elf-a310_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_sparkle_orc-a580_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_sparkle_orc-a750_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_sparkle_titan-a750_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_asus_dual-a380_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\fwdata\dg2_dell_widowmaker-a770_config-data.bin, 2/23/2024 18:28:56, 40960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\pcon\rtk\dg2_pcon_fw.bin, 2/23/2024 18:28:56, 393216 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\RTKDlls\Comm.dll, 1.03.0012.0000 (Chinese (Simplified)), 2/23/2024 19:17:18, 2989632 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\RTKDlls\LoadCScaler.dll, 1.03.0012.0000 (Chinese (Simplified)), 2/23/2024 19:17:20, 3167704 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\RTKDlls\WinOperateCScaler.dll, 1.03.0012.0000 (Chinese (Simplified)), 2/23/2024 19:17:22, 3278400 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\RTKDlls\IspSetting.ini, 2/23/2024 18:28:56, 599 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\RTKDlls\PlugIn\WinIspPlugIn.dll, 1.03.0012.0000 (Chinese (Simplified)), 2/23/2024 19:17:26, 3582528 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\RTKDlls\PlugIn\Flash.dat, 2/23/2024 18:28:56, 43539 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\RTKDlls\Comm\Comm_Aux.dll, 1.03.0012.0000 (Chinese (Simplified)), 2/23/2024 19:17:26, 3225048 bytes
     Name: AMD PSP 11.0 Device
Device ID: PCI\VEN_1022&DEV_1486&SUBSYS_7B861462&REV_00\4&8F327EB&0&0141
   Driver: C:\Windows\system32\DRIVERS\amdpsp.sys, 5.24.0000.0000 (English), 5/14/2023 10:23:56, 52120 bytes
   Driver: C:\Windows\system32\amdtee_api.dll, 5.24.0000.0000 (English), 5/14/2023 10:24:00, 438680 bytes
   Driver: C:\Windows\SysWOW64\amdtee_api.dll, 5.24.0000.0000 (English), 5/14/2023 10:23:58, 352192 bytes
Device ID: PCI\VEN_1022&DEV_1442&SUBSYS_00000000&REV_00\3&11583659&0&C2
   Driver: n/a
     Name: Realtek PCIe GbE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_7B861462&REV_15\01000000684CE00000
   Driver: C:\Windows\System32\DriverStore\FileRepository\rtcx21x64.inf_amd64_516e5c9b75c49dc2\rtcx21x64.sys, 1.00.0000.0014 (English), 5/6/2022 14:08:00, 539648 bytes
     Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_4F90&SUBSYS_60011849&REV_00\6&6EBC27F&0&00200019
   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.22621.0004 (English), 9/25/2022 03:32:49, 192512 bytes
   Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.22621.0001 (English), 5/7/2022 06:19:01, 143360 bytes
   Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.22621.0001 (English), 5/7/2022 06:19:01, 471040 bytes
Device ID: PCI\VEN_1022&DEV_1445&SUBSYS_00000000&REV_00\3&11583659&0&C5
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_790B&SUBSYS_7B861462&REV_61\3&11583659&0&A0
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1480&SUBSYS_7B861462&REV_00\3&11583659&0&00
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1440&SUBSYS_00000000&REV_00\3&11583659&0&C0
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1487&SUBSYS_CB861462&REV_00\4&8F327EB&0&0441
     Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_1022&DEV_43C8&SUBSYS_10621B21&REV_01\4&2C18E2E3&0&010B
   Driver: C:\Windows\system32\DRIVERS\storahci.sys, 10.00.22621.0382 (English), 9/25/2022 03:32:49, 214352 bytes
     Name: PCI standard ISA bridge
Device ID: PCI\VEN_1022&DEV_790E&SUBSYS_7B861462&REV_51\3&11583659&0&A3
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.22621.0001 (English), 5/7/2022 06:19:04, 54608 bytes
     Name: PCI Express Upstream Switch Port
Device ID: PCI\VEN_8086&DEV_4FA0&SUBSYS_00000000&REV_01\4&1FC990D7&0&0019
   Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.22621.0457 (English), 9/25/2022 03:32:45, 566624 bytes
Device ID: PCI\VEN_1022&DEV_1485&SUBSYS_7B861462&REV_00\4&8F327EB&0&0041
   Driver: C:\Windows\system32\DRIVERS\AMDPCIDev.sys, 1.00.0000.0090 (English), 11/3/2022 11:18:20, 39008 bytes
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&40
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&38
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&28
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&20
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&18
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&10
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1482&SUBSYS_00000000&REV_00\3&11583659&0&08
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1443&SUBSYS_00000000&REV_00\3&11583659&0&C3
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_148A&SUBSYS_7B861462&REV_00\4&27FC2A9C&0&0039
Device ID: PCI\VEN_1022&DEV_1446&SUBSYS_00000000&REV_00\3&11583659&0&C6
   Driver: n/a
     Name: PCI Express Downstream Switch Port
Device ID: PCI\VEN_8086&DEV_4FA4&SUBSYS_00008086&REV_00\5&1C448880&3&200019
Device ID: PCI\VEN_1022&DEV_43C7&SUBSYS_33061B21&REV_01\5&20AB19AA&0&20020B
Device ID: PCI\VEN_1022&DEV_43D5&SUBSYS_11421B21&REV_01\4&2C18E2E3&0&000B
Device ID: PCI\VEN_1022&DEV_43C7&SUBSYS_33061B21&REV_01\5&20AB19AA&0&08020B
Device ID: PCI\VEN_8086&DEV_4FA4&SUBSYS_4FA48086&REV_00\5&1C448880&3&080019
     Name: PCI Express Root Port
Device ID: PCI\VEN_1022&DEV_1483&SUBSYS_12341022&REV_00\3&11583659&0&19
Device ID: PCI\VEN_1022&DEV_1483&SUBSYS_12341022&REV_00\3&11583659&0&0B
Device ID: PCI\VEN_1022&DEV_1441&SUBSYS_00000000&REV_00\3&11583659&0&C1
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1484&SUBSYS_14627B86&REV_00\3&11583659&0&41
Device ID: PCI\VEN_1022&DEV_1484&SUBSYS_14627B86&REV_00\3&11583659&0&39
Device ID: PCI\VEN_1022&DEV_43C7&SUBSYS_33061B21&REV_01\5&20AB19AA&0&00020B
Device ID: PCI\VEN_1022&DEV_1444&SUBSYS_00000000&REV_00\3&11583659&0&C4
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_43C6&SUBSYS_02011B21&REV_01\4&2C18E2E3&0&020B
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.22621.0001
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.22621.0001
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.22621.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.22621.0105
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.22621.0001
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.22621.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.22621.0001
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.22621.0001
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.22621.0001
DV Muxer,0x00400000,0,0,qdv.dll,10.00.22621.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.22621.0001
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.22621.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.22621.0001
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.22621.0001
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.22621.0001
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.22621.0521
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.22621.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.22621.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.22621.0001
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.22621.0001
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.22621.0001
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.22621.0001
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.22621.0001
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.22621.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.22621.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.22621.0001
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.22621.0001
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.22621.0001
DV Splitter,0x00600000,1,2,qdv.dll,10.00.22621.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.22621.0001
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.22621.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.22621.0001
Video Renderer,0x00800001,1,0,quartz.dll,10.00.22621.0001
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.22621.0001
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.22621.0001
Video Renderer,0x00400000,1,0,quartz.dll,10.00.22621.0001
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.22621.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.22621.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,10.00.22621.0001
File writer,0x00200000,1,0,qcap.dll,10.00.22621.0001
AVI Draw,0x00600064,9,1,quartz.dll,10.00.22621.0001
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.22621.0001
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.22621.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.22621.0001
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.22621.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.22621.0001
Null Renderer,0x00200000,1,0,qedit.dll,10.00.22621.0001
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.22621.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.22621.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.22621.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.22621.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.22621.0001
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.22621.0001
Wave Parser,0x00400000,1,1,quartz.dll,10.00.22621.0001
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.22621.0001
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.22621.0001
File stream renderer,0x00400000,1,1,quartz.dll,10.00.22621.0001
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.22621.0001
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.22621.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.22621.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.22621.0001
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.22621.0001
File Source (URL),0x00400000,0,1,quartz.dll,10.00.22621.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.22621.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.22621.0001
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.22621.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.22621.0001
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.22621.0001
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.22621.0001
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.22621.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.22621.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.22621.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.22621.0001
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.22621.0001
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.22621.0001
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.22621.0001
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.22621.0001
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.22621.0001
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.22621.0001
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.22621.0001
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.22621.0001
Audio Capture Sources:
Microphone (High Definition Audio Device),0x00200000,0,0,qcap.dll,10.00.22621.0001
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.22621.0317
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.22621.0317
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.22621.0317
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.22621.0001
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.22621.0001
WDM Streaming Capture Devices:
HD Audio Mixed capture,0x00200000,1,1,ksproxy.ax,10.00.22621.0001
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
HD Audio Speaker,0x00200000,1,1,ksproxy.ax,10.00.22621.0001
ACX HD Audio Speaker,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.22621.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.22621.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.22621.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.22621.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.22621.0001
Video Capture Sources:
Intel Virtual Camera,0x00200000,0,1,VirtualCamDevice.dll,1.00.0000.0001
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.22621.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.22621.0001
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,10.00.22621.0001
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.22621.0001
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.22621.0001
DirectSound: Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,10.00.22621.0001
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation File Versions
  mfcore.dll, 10.00.22621.0525
  mfreadwrite.dll, 10.00.22621.0001
  mfcaptureengine.dll, 10.00.22621.0001
  mfsensorgroup.dll, 10.00.22621.0457
  windows.media.dll, 10.00.22621.0317
  frameserver.dll, 10.00.22621.0457
  frameserverclient.dll, 10.00.22621.0457
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
  <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
  Intel® Hardware M-JPEG Decoder MFT, {00C69F81-0524-48C0-A353-4DD9D54F9A6E}, 0x6, 7, mfx_mft_mjpgvd_64.dll, 24.01.0016.4404
  Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.22621.0521
  DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.22621.0001
  Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.22621.0001
  Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.22621.0521
  WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.22621.0001
  WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.22621.0001
  MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.22621.0001
  Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.22621.0001
  Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.22621.0001
Video Encoders:
  Intel® Quick Sync Video H.264 Encoder MFT, {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}, 0x4, 7, mfx_mft_h264ve_64.dll, 24.01.0016.4404
  Intel® Hardware H265 Encoder MFT, {BC10864D-2B34-408F-912A-102B1B867B6C}, 0x4, 7, mfx_mft_h265ve_64.dll, 24.01.0016.4404
  Intel® Hardware VP9 Encoder MFT, {D186A626-77CA-4D80-942F-61E0A5111AFE}, 0x4, 7, mfx_mft_vp9ve_64.dll, 24.01.0016.4404
  Intel® Hardware AV1 Encoder MFT, {F4ECF9A2-36A6-42C4-B284-A05181FD7490}, 0x4, 7, mfx_mft_av1ve_64.dll, 24.01.0016.4404
  H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.22621.0001
  WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.22621.0001
  H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.22621.0001
  WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.22621.0001
  Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.22621.0001
Video Effects:
  Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.22621.0001
  Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.22621.0001
  VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.22621.0317
  Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.22621.0001
  Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.22621.0001
Video Processor:
  Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.22621.0105
Audio Decoders:
  Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.22621.0317
  MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.22621.0001
  WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.22621.0001
  Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.22621.0317
  A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.22621.0525
  GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.22621.0525
  WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.22621.0001
  Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.22621.0001
  Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.22621.0001
  Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.22621.0317
  WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.22621.0001
  G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.22621.0525
  IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.22621.0525
  MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.22621.0105
  Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.22621.0001
  ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.22621.0525
  Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.22621.0001
  DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.22621.0001
Audio Encoders:
  LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.22621.0001
  MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.22621.0525
  Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.22621.0001
  WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.22621.0001
  MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.22621.0001
  Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.22621.0001
  WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.22621.0001
  Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.22621.0001
  Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.22621.0001
  Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.22621.0001
Audio Effects:
  AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.22621.0001
  Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.22621.0105
Multiplexers:
  Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.22621.0457
Others:
  Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.22621.0521
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableEncoders = 1
EnableDecoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D8033-DB46-11CF-B4D1-00805F6CBBEA}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
{C2FE6F0A-4E3C-4DF1-9B60-50863091E4B9}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
No Data
+++ WER1 +++:
No Data
+++ WER2 +++:
No Data
+++ WER3 +++:
No Data
+++ WER4 +++:
No Data
+++ WER5 +++:
No Data
+++ WER6 +++:
No Data
+++ WER7 +++:
No Data
+++ WER8 +++:
No Data
+++ WER9 +++:
No Data
ACarmona_Intel
Hello ALAK,
Thank you so much for the response.
We will wait for you, SSU, so we can further isolate the issue.
Thank you, and have a great day ahead!
Carmona A.
ALAK
# SSU Scan Information
Scan Info:
Version:"3.0.0.2"
Date:"03/02/2024"
Time:"00:00:19.1358495"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Micro-Star International Co., Ltd"
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends International, LLC. H.I0 , 06/30/2023 12:00 AM"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"AMD Ryzen 5 5600X 6-Core Processor , AuthenticAMD"
Secure Boot State:"Off"
SMBIOS Version:"2.8"
Sound Card:"High Definition Audio Device"
System Manufacturer:"Micro-Star International Co., Ltd"
System Model:"MS-7B86"
System SKU:"To be filled by O.E.M."
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) Arc(TM) A770 Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"3.91 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Arc(TM) A770 Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Arc+A770+Graphics"
CoInstallers:"oem0.inf,iDG2_Client_FWU_w10_DS,Internal,Intel(R) Arc(TM) A770 Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmdnd64.sys"
Driver Date:"02/21/2024 01:00 AM"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdkmdnd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"31.0.101.5333"
INF:"oem0.inf"
INF Section:"iDG2_Client_FWU_w10_DS"
Install Date:"Not Available"
Installed Drivers:"C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4c7e79e3f590471c\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_56A0&SUBSYS_60011849&REV_08\6&177769E6&0&00080019"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"144 Hz"
Refresh Rate - Maximum:"144 Hz"
Refresh Rate - Minimum:"23 Hz"
Resolution:"1920 X 1080"
Scan Mode:"Noninterlaced"
Service Name:"igfxnd"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Arc(TM) A770 Graphics Family"
- "Memory"
Physical Memory (Available):"13.29 GB"
Physical Memory (Installed):"24 GB"
Physical Memory (Total):"23.93 GB"
- "P0 CHANNEL A"
Capacity:"8 GB"
Channel:"DIMM 1"
Configured Clock Speed:"3000 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"Not Available"
Manufacturer:"Unknown"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"CMK16GX4M2D3000C16"
Serial Number:"00000000"
Status:"Not Available"
Type:"Not Available"
- "P0 CHANNEL B"
Capacity:"8 GB"
Channel:"DIMM 0"
Form Factor:"DIMM"
Part Number:"BLS8G4D30AESBK.M8FE"
Serial Number:"E2643D05"
- "P0 CHANNEL B"
Capacity:"8 GB"
Channel:"DIMM 1"
Form Factor:"DIMM"
- "Motherboard"
BIOS:"H.I0, ALASKA - 1072009"
Caption:"Motherboard"
Chipset:"Not Available"
Date:"06/30/2023 01:00 AM"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"ACPI\PNP0C01\C8"
Product:"B450 GAMING PLUS MAX (MS-7B86)"
Serial Number:"To be filled by O.E.M."
Status:"OK"
Version:"3.0"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Realtek PCIe GbE Family Controller"
Caption:"Realtek PCIe GbE Family Controller"
CoInstallers:"Not Available"
Default IP Gateway:"192.168.0.1"
DHCP Enabled:"Yes"
DHCP Lease Expires:"03/09/2024 02:58 PM"
DHCP Lease Obtained:"03/02/2024 02:58 PM"
DHCP Server:"192.168.0.1"
Driver:"rtcx21x64.sys"
Driver Date:"02/01/2021 12:00 AM"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\rtcx21x64.inf_amd64_516e5c9b75c49dc2\rtcx21x64.sys"
Driver Provider:"Microsoft"
Driver Version:"1.0.0.14"
Index:"0000"
INF:"rtcx21x64.inf"
INF Section:"RTL8168H.ndi.NT"
Installed:"Yes"
IP Address:"192.168.0.4"
IP Subnet:"255.255.255.0"
Last Reset:"03/02/2024 02:58 PM"
MAC Address:"2C:F0:5D:7B:D5:B1"
Manufacturer:"Realtek"
Net Connection ID:"Ethernet"
NetCfgInstanceId:"{E8F99C71-9709-48A1-BA49-13915A3BC32C}"
PNP Device ID:"PCI\VEN_10EC&DEV_8168&SUBSYS_7B861462&REV_15\01000000684CE00000"
Port:"Not Available"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: Yes"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: Yes"
Power Management Supported:"No"
Product Type:"Realtek PCIe GbE Family Controller"
Service Name:"rtcx21"
Status:"Enabled"
Type:"Ethernet 802.3"
- "Service Bindings"
Internet Protocol Version 4 (TCP/IPv4):
QoS Packet Scheduler:
- "Settings"
*FlowControl:Flow Control:"Disabled (0)"
*InterruptModeration:Interrupt Moderation:"Disabled (0)"
*IPChecksumOffloadIPv4:IPv4 Checksum Offload:"Disabled (0)"
*JumboPacket:Jumbo Frame:"Disabled (1514)"
*LsoV2IPv4:Large Send Offload v2 (IPv4):"Disabled (0)"
*LsoV2IPv6:Large Send Offload v2 (IPv6):"Disabled (0)"
*PMARPOffload:ARP Offload:"Disabled (0)"
*PMNSOffload:NS Offload:"Disabled (0)"
*PriorityVlanTag:Priority & VLAN:"Priority & VLAN Disabled (0)"
*ReceiveBuffers:Receive Buffers:"512 (512)"
*RscIPv4:Recv Segment Coalescing (IPv4):"Disabled (0)"
*RscIPv6:Recv Segment Coalescing (IPv6):"Disabled (0)"
*SpeedDuplex:Speed & Duplex:"1.0 Gbps Full Duplex (6)"
*TCPChecksumOffloadIPv4:TCP Checksum Offload (IPv4):"Disabled (0)"
*TCPChecksumOffloadIPv6:TCP Checksum Offload (IPv6):"Disabled (0)"
*TransmitBuffers:Transmit Buffers:"128 (128)"
*UDPChecksumOffloadIPv4:UDP Checksum Offload (IPv4):"Disabled (0)"
*UDPChecksumOffloadIPv6:UDP Checksum Offload (IPv6):"Disabled (0)"
*WakeOnMagicPacket:Wake on Magic Packet:"Disabled (0)"
*WakeOnPattern:Wake on pattern match:"Disabled (0)"
RegVlanid:VLAN ID:"0 (0)"
S5WakeOnLan:Shutdown Wake-On-Lan:"Disabled (0)"
WolShutdownLinkSpeed:WOL & Shutdown Link Speed:"Not Speed Down (2)"
- "Operating System"
.Net Framework Version:"4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Internet Browser:"Google Chrome,122.0"
Locale:"United States"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 11 Home"
Other OS Description:"Not Available"
Page File:"Not Available"
Page File Space:"Not Available"
Physical Memory (Available):"13.21 GB"
System Directory:"C:\Windows\system32"
Version:"10.0.22621 Build 22621"
Virtual Memory (Available):"6.03 GB"
Virtual Memory (Total):"23.93 GB"
Windows Directory:"C:\Windows"
- "Installed Updates"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB5017026:"Update [9/25/2022]"
KB5017233:"Security Update [9/25/2022]"
KB5019311:"Update [9/25/2022]"
Microsoft ASP.NET Core 7.0.7 - Shared Framework (x64):".NET [3/1/2024]"
- "Processor"
Not Available:
- "Storage"
- "CT240BX500SSD1"
Capablities:"Random Access, Supports Writing, SMART Notification"
Caption:"CT240BX500SSD1"
Cylinder - Total:"29185"
Description:"Disk drive"
Driver:"Not Available"
Driver Date:"06/21/2006 12:00 AM"
Driver Version:"10.0.22621.317"
Error Code:"Device is working properly"
Firmware Revision:"M6CR013"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Interface Type:"IDE"
Manufacturer:"(Standard disk drives)"
Model:"CT240BX500SSD1"
Partitions:"2"
PNP Device ID:"SCSI\DISK&VEN_&PROD_CT240BX500SSD1\5&2B637674&0&000000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
Sectors - Per Track:"63"
Sectors - Total:"468857025"
Serial Number:"2003E3E290FD"
Size – Available:"173.07 GB"
SMART Attributes:"Self-Test: 10 minutes, OK, Short Self-Test: 2 minutes, OK"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"7442175"
- "C:"
Availability:"Not Available"
Caption:"C:"
Compression Method:"Not Compressed"
Description:"Local Fixed Disk"
File System:"NTFS"
Name:"Not Available"
Serial Number:"4C4475A0"
Size – Available:"173.08 GB"
Volume Dirty:"No"
- "SMART"
0x01 Raw Read Error Rate:0:"50"
0x05 Reallocated Sector Count:0:"10"
0x09 Power-On Hours:13157:"50"
0x0C Power Cycle Count:3246:"50"
0xAB Program Fail Count:0:"50"
0xAC Erase Fail Count:0:"50"
0xAD Wear Leveling Count:534:"50"
0xAE Power-off Retract Count:913:"50"
0xB4 Unused Reserved Block Count Total:100:"50"
0xB7 SATA Downshift Count:0:"50"
0xB8 End-to-End Error Detection Count:0:"50"
0xBB Uncorrectable Error Count:0:"50"
0xC2 Internal Device Temperature:46° C:"50"
0xC4 Reallocation Count:0:"50"
0xC5 Current Pending Errors Count:0:"50"
0xC6 Uncorrectable Sector Count:0:"50"
0xC7 CRC Error Count:1:"50"
0xCA Data Address Mark Errors:65:"1"
0xCE Flying Height:0:"50"
0xD2 Vibration During Write:0:"50"
...#SSU#...
#Logs#System Messages#No Log
ACarmona_Intel
Hello ALAK,
Thank you so much for the response. However, is it possible that you can share the text file of your SSU? Once I have your SSU.txt file, I will immediately gather information with regards to our issue.
Carmona A.
ACarmona_Intel
Hello ALAK,
Please provide your SSU text file so we can further isolate our issue.
Thank you, and have a great day!
Carmona A.
ALAK
ACarmona_Intel
Hello ALAK,
We truly appreciate you informing us that the problem has been fixed. If, in the future, you will need our assistance again, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
