Intel® Arc™ Discrete Graphics
4063 Discussões
BSoD, igdkmdnd64.sys SYSTEM_THREAD_EXCEPTION_NOT_HANDLED, only when playing No Man's Sky
GLKraken
Novato
19.995 Visualizações
So, ever since I got a new Display Port Monitor I haven't had any problems with my A750 LE graphics card. But now I decided to play a new game ( No man's sky ) and It runs just fine, with a few stutters, but after playing for about 30+ minutes, my pc will randomly get a BSoD, also Alt+tabbing the game is kind of weird if I don't put it in windowed mode.
Mobo: TUF GAMING B650M PLUS WIFI
CPU: Ryzen 5 7600X
RAM: 32GB GSkill triden 6000mhz ( tried XMP on/off already )
GPU: ARC A750 LE (32.0.101.6332 and 32.0.101.6325 used, both with the same error)
Temperatures are just fine, gpu never goes 75C+. Cpu 70C-.
I'm not sure if I should post this here or with NMS support, since the error is the intel graphics driver I suposse It is fine here.
The crash doesn't happen If I never open No Man's sky, but if I open it, even after closing it, it will crash randomly.
I have the dmp file but won't let me post it here, so I put it into a txt file, any other information required can be provided if asked.
Etiquetas (1)
1 Solução
DeancR_Intel
Moderador
16.493 Visualizações
Hi GLKraken,
I hope you're doing well, and I appreciate your patience throughout the process. To help improve your experience with "No Man's Sky," I recommend updating to the latest Intel Arc & Iris Xe Graphics Driver, version 32.0.101.6874 (WHQL Certified). This update may enhance compatibility and performance for your game.
You can download the driver here: Intel Arc & Iris Xe Graphics Driver.
If you need any assistance with the installation, feel free to reach out.
Dean R.
Ver solução na publicação original
35 Respostas
DeancR_Intel
Moderador
11.819 Visualizações
Hi GLKraken,
Thank you for posting in the Community!
I suggest doing the following steps here:
  • A clean driver installation using DDU in safe mode is recommended. Follow this link for instructions.
  • You could also test using the latest non-WHQL driver. This driver goes through all Intel quality assurance processes and is safe to use for evaluation.
Let me know if you any other questions.
Dean R.
GLKraken
Novato
11.794 Visualizações
Hello, ty for answering
I already tried doing DDU, and when I get time I'll try using non WHQL driver, I'm going to use 32.0.101.6332/32.0.101.101.6253.
And what @verdich linked looks very similar to what I'm getting too, sadly if I downgrade to the driver mentioned there I don't get the optimizations for marvel rivals.
verdich
Novo colaborador I
11.806 Visualizações
GLKraken
Novato
11.770 Visualizações
Wanted to add: Counter Strike 2 seems to have the very same issue
GLKraken
Novato
11.673 Visualizações
So even with non WHQL 32.0.101.6332/32.0.101.101.6253 the bug is there.
DeancR_Intel
Moderador
11.654 Visualizações
Hi GLKraken,
I suggest the following steps here:
Here's the link for reference:
Bluescreen Error message " igdkmdnd64.sys " On Intel®...
Dean R.
GLKraken
Novato
11.581 Visualizações
1st, all requirements are met for Intel ARC A-SERIES graphics
I did a clean installation of with non WHQL 32.0.101.6332/32.0.101.101.6253 drivers, and 32.0.101.6332, Gonna try this sunday to do it
again with the newest drivers
There hasn't been any software changes or hardware changes
Windows is updated to the latest version, I'm using Windows 23H2 22631.4602
The BIOS for my Mobo is 1811, so I'm going to update to the latest one ( also in sunday because of free time )
Resizable BAR is also enabled
6600XT works fine in this PC, sadly I can't test the A750 in another system since there are no other computers avaiable for me that have Smart Access memory or Resizable BAR.
Thank you for answering, I'll try to follow up in sunday
GLKraken
Novato
11.524 Visualizações
Updated BIOS to latest version, Updated Drivers using DDU, the bug is still there.
Something I wanted to note, since i just noticed, before the crash there will be like a small freeze when alt + tabbing. When I check in event viewer the freeze has the exact same time the system logs the display controller (igfxnd) stopped working and was recovered succesfully ( and it didn't crash ). AND, after that small freeze, even if i close the game, I notice the crash will happen anyways, it becomes a matter of time.
For now only games making this crash are Counter Strike 2 and No Man's sky, the crash won't happen in No Man's sky's menu
DeancR_Intel
Moderador
11.454 Visualizações
Hi GLKraken,
This is an acknowledgement message for your case, do please wait as this concern will be investigated internally to be able to provide a resolution to your request. I will get back to your once I have the necessary information.
Dean R.
GLKraken
Novato
11.422 Visualizações
Ty for answering, I won't be avaiable next week so if you ask for something, I'll be answering 28-29th January.
o7
ACarmona_Intel
Funcionário
11.373 Visualizações
Hello GLKraken,
Thank you so much for the response, and I understand that you wouldn't be able to respond to us until January 27th.
For our next step, please share with us your SSU logs so we can further analyze your system specifications and configurations.
To generate the SSU report, please refer to the article: How to Get the Intel® System Support Utility Logs on Windows. Please send us the generated SSU.txt file.
Furthermore, we have a new release driver: 32.0.101.6458/32.0.101.6257. Please try to install it and check if the issue will still persist.
Looking forward to your update!
Carmona A.
jxn
Novo colaborador I
11.307 Visualizações
Hello, I would like to add to this thread that I am experiencing similar issues. I'm on an arc a750 and clean installing the newest drivers with DDU hasn't resolved these BSODs. Should I open a new forum thread for my specific case or should I add to this existing thread?
Cheers.
verdich
Novo colaborador I
11.275 Visualizações
Hey @jxn!
I think you might find that the 32.0.101.6078 WHQL driver allows you run without experiencing these BSODs. Intel has told me that they consider it a hardware issue, so you may also want to look into warranty and possibly going through an RMA process.
https://github.com/IGCIT/Intel-GPU-Community-Issue-Tracker-IGCIT/issues/874
I'll add that I think the Intel team has handled this very well - at least in my case. The BSOD issues seem to affect a minority of the cards out there and I know first hand how hard it can be to diagnose such things without being able to reproduce them. I hope you find a solution!
Kasper
jxn
Novo colaborador I
11.213 Visualizações
Thanks for your reply @verdich ,
I am currently testing the 6078 drivers, and so far I haven't gotten any BSODs after reverting to these drivers. I will report back with any findings, and if the issue persists, will go through the RMA process as per your advice.
Thanks!
DeancR_Intel
Moderador
11.246 Visualizações
Hi GLKraken,
I wanted to follow up on the previous message from @ACarmona_Intel regarding your inquiry. Have you had a chance to review it? If you have any questions or need further information, please let me know.
Hi jxn,
This is noted however, I suggest creating a new thread for this to avoid further confusions.
Dean R.
GLKraken
Novato
11.226 Visualizações
Yeah I just returned and read it, I'll install the drivers and do the SSU report today's night or tomorrow's night
Thank you for waiting this week
jxn
Novo colaborador I
Thank you @DeancR_Intel , I will create a new thread if my issue still persists after the measures, per @verdich .
lamhirh
Novato
11.200 Visualizações
I am having the same issue with no man sky since around mid -late December. The game used to work fine, then started having issues.
First game starts to stutter, and the bluescreens anytime between 15-30 minutes from starting the game. Bsods are igkmdm.sys related
Multiple clean installs have been done since.
GLKraken
Novato
11.172 Visualizações
Okay got the SSU Report, I didn't update the drivers since I saw no changes were made to A-Series graphics card and jxn had tested it. ( If you require me to do so, tell me, I just wanted to save me some time )
If something else is required I can help, like making the crash happen and after that making the ssu report or something.
Thank you for your work!
DeancR_Intel
Moderador
11.152 Visualizações
Hi GLKraken,
There's a new driver released for your graphics card, here's the link for reference: Intel® Graphics Driver 32.0.101.6460/32.0.101.6259.
I would like you to try this driver and apply clean installation. Let me know if the issue still persists. Here's the link for reference:
Clean Installation of Intel® Graphics Drivers in Windows*
Hi lamhirh,
This is noted however, please submit a new ticket with regards to your issue to avoid confusions.
Dean R.
Responder
