So the ARC seems to get bottenecked like a ton.In valves deadlock i get really inconsistent FPS and gpu usage(60-70%) UNLESS i have FSR3 on native which then works at 90 to 100%, it seems weird that there is bottlenecking on this cpu and it doesnt run hot, i have rebar, I re-installed windows 11 and got the newest bios.
I tried to see if I can do something myself to fix this because I think something else is going on.
I have tested ARC Raiders, BF5 which 1% lows are down to the 30-40 for some reason, the finals which has the same gpu usage problem unless i have some powerfull Dlss running in native like in deadlock.
I tried overclocking my cpu by the Amd ryzen app with their optimizer (did not do it manual, let the auto detect do the work) and games seem to run better on frames but even worse on the 1%lows.
All around bad experience because I got the arc B580 to upgrade from an RTX 2060 6GB, from the researched I did then the Ryzen 5 5600g I had would bottleneck it just a bit but it wouldn't be like unplayble.It was terrible. So then I say ok lets upgrade to a ryzen 7 5700x I thought it would be just perfect and people I asked said it would be good pairing and do the job.The R7 run hot (90- 95c)with my old cooler so games would stutter.I bought new cooler the temps dont go over 60c and games indeed run better but the GPU utilization thing stil hangs around.
Anyone please give some insight maybe even some help.
I got a 650 silver PSU (Decent brand cant remember the name rn)
16 gb DDR4 2133 (Yes i know not the greatest.)
Intel arc b580
ryzen 7 5700x
ASROCK B450PRO R.2 motherboard with rebar
NVME drives for storage
Hi tzon1,
Thank you for posting in our Community and for the troubleshooting steps you’ve already completed. I can see you’ve been very thorough in trying to identify the cause of the inconsistent GPU usage and performance drops with your Intel® Arc™ B580 and Ryzen 7 5700X combination. To help me look deeper into this, could you please confirm the following details:
- Have you tested with Resizable BAR (ReBAR), both enabled and disabled, to compare results?
- Could you share your in-game graphics settings (especially in Deadlock and Battlefield 5) and your display resolution/refresh rate?
- Are you running any background monitoring or recording software (such as MSI Afterburner, RivaTuner, or CapFrameX) while gaming?
- Have you checked your memory (RAM) speed and XMP/DOCP profile in BIOS to ensure it’s properly enabled? DDR4-2133 can limit performance in some cases.
Additionally, I'd like to delve deeper and verify specifics like the graphics models, precise driver versions, and any system errors. Utilizing the Intel SSU tool will enable me to collect detailed information about your system setup, which could aid in identifying the underlying cause of this issue.
Have a nice day!
Von M.
Hello tzon1,
Von M.
Hello tzon1,
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
