Intel® Arc™ Discrete Graphics
4123 Discussions
CS:GO issues with 4369
Cebos
Hi, last night I installed the new 4369 driver but it has made CS:GO virtually unplayable.  Screen does 2 second lockups every few seconds and fps spiking.  I rolled back to 4335 just now and that problem has gone away and constantly getting 3xx fps.  I also found myself changing BF2042 gfx settings after installing the new driver as it just didnt feel as solid as it usually did.
Brad
Cebos
Ok so I did a DDU clean and restart while in safe mode, then reinstalled 4369 and CS:GO and everything seems perfect now.
Jean_Intel
Hello Cebos,
We are glad to hear that everything is working fine after running DDU and installing the .4369 driver one more time. Sometimes, corrupted files from previous drivers may cause driver updates to not work as expected. Doing a clean install of the software/drivers for any hardware can help to fix specific issues that can be associated so any additional software that might be causing malfunction.
We will keep this thread open for a few days in case the issue occurs again. Let us know if you face any inconvenience.
Best regards
Jean O.
Jean_Intel
Hello Cebos,
We hope you are doing fine.
Best regards.
Jean O.
