Intel® Arc™ Discrete Graphics
3557 Discussions
Call of duty modern warfare 3
Oranhh123
i have been trying to play Call of Duty Modern Warfare 3 on my computer. Nothing other than the HUD and particle effects will render, though. IIMG_5B99093A-BDB5-4371-BC76-8FDEF0899313 (1).JPEG am using an Intel Arc B580 with a Ryzen 5 9600X, I already have the latest drivers.
Oranhh123
this issue does not appear in any other call of duty game. it is only modern warfare 3
DeancR_Intel
Hi Oranhh123,
Thank you for contacting Intel Customer Support regarding the rendering issues you're experiencing with Call of Duty Modern Warfare 3 on your Intel Arc B580 graphics card. I can see from your screenshot that only the HUD and particle effects are rendering while the main game environment is not displaying properly, which is certainly a concerning issue.
I appreciate you mentioning that this problem is specific to Modern Warfare 3 and doesn't occur in other Call of Duty games, which helps narrow down the potential causes.
To better assist you in resolving this rendering issue, I need to gather some additional information:
System History:
  1. Was this game working properly before? If so, when did this rendering issue first start occurring?
  2. When did you first notice this problem? Was it after a recent game update, driver update, or system change?
System Information: For comprehensive troubleshooting, could you please provide an Intel System Support Utility (SSU) report? You can download it from: https://www.intel.com/content/www/us/en/support/articles/000005511/processors.html
If you're not comfortable generating an SSU report, please provide:
  • CPU Model: (You mentioned Ryzen 5 9600X)
  • Exact GPU Model: Intel Arc B580 (confirmed)
  • Current Driver Version: You mentioned having the latest drivers could you confirm the exact Intel Arc driver version number?
Clean Installation: Have you tried using DDU (Display Driver Uninstaller) to perform a clean installation of your Intel Arc drivers? This can resolve rendering conflicts that sometimes occur with specific games.
Driver Update Recommendation: Please try updating to the latest Intel Arc graphics driver and perform a clean installation:
  1. Download DDU (Display Driver Uninstaller): https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
  2. Download Latest Intel Arc Driver: https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
  3. Clean Installation Process:
  • Boot into Safe Mode
  • Run DDU to remove current graphics drivers
  • Restart in normal mode
  • Install the latest Intel Arc driver
Given the specific nature of this game rendering issue, I'd like to offer you a phone consultation. This would allow us to work through troubleshooting steps more efficiently and potentially resolve this Modern Warfare 3 rendering problem more quickly.
Dean R.
Oranhh123
I just got the game recently, and it has never worked properly for me. I have attached the SSU. I was unable to run the clean driver installation, as when I booted into safe mode, the sign-in told me that there was an issue with my PIN and I needed to change it, which it wouldn't let me do because I was in safe mode. my graphics driver is version 32.0.101.7029
DeancR_Intel
Hi Oranhh123,
Thank you for providing the SSU report and for clarifying that this is a new game purchase that has never worked properly for you. I also understand the difficulty you encountered with the PIN issue when trying to boot into Safe Mode, this is a common Windows security feature that can complicate the DDU process.
Since you're unable to perform the DDU clean installation due to the Safe Mode PIN restriction, let's try a different approach with the latest driver update.
There's a newer Intel Arc graphics driver available that may resolve the Modern Warfare 3 rendering issues you're experiencing:
Intel Graphics Driver Version: 32.0.101.7076
Download Link: https://www.intel.com/content/www/us/en/download/864990/864992/intel-11th-14th-gen-processor-graphi…
Installation Instructions (Without Safe Mode):
  1. Download the new driver version 32.0.101.7076 from the link above
  2. Uninstall your current Intel Arc driver (32.0.101.7029) through Windows Settings → Apps → Intel Graphics Driver
  3. Restart your computer
  4. Install the new driver version 32.0.101.7076
  5. Restart again after installation
  6.
Why This May Help:
  • Driver version 32.0.101.7076 includes the latest game compatibility improvements
  • Modern Warfare 3 may require specific optimizations that weren't available in version 7029
  • This newer driver often resolves rendering issues with recently released games
Once you've installed driver version 32.0.101.7076, please test Modern Warfare 3 and let me know:
  • Whether the main game environment now renders properly
  • If you still only see HUD and particle effects
  • Any improvements or changes you notice
Please try this driver update and report back with the results.
Dean R.
Oranhh123
hi dean, the link you provided appears to be the drivers for the integrated graphics on an intel cpu, not for an intel arc GPU
DeancR_Intel
Hi Oranhh123,
I sincerely apologize for the confusion with the driver link I provided earlier. Here is the correct driver download for your Intel Arc GPU:
Intel Arc Graphics Driver Version: 32.0.101.8132 Download Link: https://www.intel.com/content/www/us/en/download/785597/intel-arc-graphics-windows.html
Once you've installed the correct Intel Arc driver version 32.0.101.8132, please test Modern Warfare 3 and let me know: Again, I apologize for the earlier confusion and thank you for your patience.
Dean R.
Oranhh123
i have installed 8132 and the issue has not gone away
DeancR_Intel
Hi Oranhh123,
Thank you for installing the latest Intel Arc driver version 32.0.101.8132 and testing Modern Warfare 3. I sincerely apologize that the rendering issue persists even after the driver update, I understand how frustrating this must be, especially since this is a new game purchase that has never worked properly for you.
Your patience throughout this troubleshooting process has been greatly appreciated, and I want to ensure we find a resolution for this Modern Warfare 3 rendering problem where only HUD and particle effects display while the main game environment remains invisible.
Given that the latest driver installation hasn't resolved the issue, I will be checking this matter internally with our specialized team. This specific rendering behavior in Modern Warfare 3 where other Call of Duty games work perfectly but MW3 shows only UI elements and particles requires deeper investigation.
I will get back to you with an update once I have more information available from our internal investigation.
Dean R.
DeancR_Intel
Hi Oranhh123,
Thank you for your patience as we continue investigating the rendering issues you're experiencing with Call of Duty Modern Warfare 3 on your Intel Arc B580 graphics card.
I've been working on your case where only HUD elements and particle effects render properly while the main 3D game environment remains invisible. Your comprehensive troubleshooting efforts, including the driver updates to version 32.0.101.8132 and providing the SSU report, have been very helpful for our analysis.
Before we proceed with further investigation and potential replication testing, I need some additional specific details about your game configuration:
1. Resizable BAR Status:
  • Is Resizable BAR (ReBAR) enabled in your system BIOS?
  • If you're unsure, please check your BIOS settings under PCIe or Advanced settings
2. Game Settings Documentation:
  • Could you please provide a screenshot of your exact Call of Duty Modern Warfare 3 graphics settings?
  • Include all graphics options, resolution, quality presets, and any advanced settings
  • This will help us replicate your exact configuration for testing
3. Issue Location Specificity:
  • Is this rendering problem happening in the game menus, or only during gameplay?
  • Does it occur in any specific part of the game or map?
  • If it's map-specific, please let me know which maps or game modes are affected
The information you provide will be crucial for the replication testing and analysis.
System Configuration Confirmed:
  • Graphics Card: Intel Arc B580
  • CPU: AMD Ryzen 5 9600X
  • Driver: 32.0.101.8132 (latest)
  • Issue: MW3-specific (other COD games work normally)
Please provide the requested information at your earliest convenience, and I'll continue with the investigation process.
Dean R.
DeancR_Intel
Hi Oranhh123,
Current Investigation Status: Your case has been prioritized for specialized investigation due to the unique nature of this Modern Warfare 3 rendering issue with Intel Arc B580. The information you provide will be crucial for our replication testing and analysis.
Dean R.
Oranhh123
Hi dean, I do have resizable bar enabled, the issue occurs in all parts of the game, and my current graphics settings are:
Display mode: fullscreen borderless
Display Adapter: Intel[R] Arc[TM] B580 Graphics
Display resolution: 1920x1080
V-Sync: Off
Menu Render Resolution: Native
Graphics preset: Recommended
Upscaling/Sharpening: Intel XESS
VRAM Scale Target: 80
texture resolution: High
texture filter anisotropic: High
depth of field: on
particle resolution: high
bullet impacts: on
persistent effects: on
shader quality: high
on demand texture streaming: optimized
local texture streaming quality: normal
shadow quality: normal
screen space shadows: high
ambient occlusion: both
screen space reflections: normal
static reflection quality: high
tessellation: near
volumetric quality: high
deferred physics quality: high
weather grid volumes: high
water quality: wave wetness
DeancR_Intel
Hi Oranhh123,
Thank you for providing the detailed graphics settings information and confirming that Resizable BAR is enabled on your system. This is very helpful for our investigation process.
I can see you've provided comprehensive graphics settings details, which will be crucial for replicating your exact configuration during our testing. I appreciate you taking the time to document all these settings thoroughly.
However, I still need a couple of additional details to complete our investigation setup:
  • Issue Location Specificity: You mentioned the issue occurs in "all parts of the game" - could you clarify if this includes:
    • Game menus (main menu, settings, etc.)
    • Loading screens
    • All gameplay modes (campaign, multiplayer, etc.)
    • All maps, or are there any specific maps where it's worse/better?
Once I have these final details, I can proceed with the comprehensive replication testing using your exact system configuration and game settings.
Thank you for your continued patience and cooperation.
Dean R.
Oranhh123
The issue occurs on all maps and in the game lobby. The loading screens are all pre-rendered images or videos that just get played back, so they have not been an issue.  Cutscenes in the campaign also work fine because they are all just videos that get played back
DeancR_Intel
Hi Oranhh123,
Thank you for the additional clarification regarding where the rendering issue occurs. This information is very helpful for our investigation.
I understand now that:
  • The issue affects all maps and the game lobby
  • Loading screens work fine (as they're pre-rendered)
  • Campaign cutscenes work fine (as they're video playback)
  • The problem specifically affects real-time 3D rendered content
This pattern helps narrow down the issue to the real-time rendering engine, which is valuable information for our technical analysis.
I have all the necessary information now, including your detailed graphics settings from your previous message. I can proceed with comprehensive replication testing using your exact system configuration and game settings.
I'll begin the replication process and get back to you with our findings as soon as possible.
Thank you for your patience and detailed responses throughout this process.
Dean R.
ArchieD_Intel
Hi Oranhh123,
I'm currently investigating this issue and will update you as soon as possible. Thank you for your patience.
Archie D.
Julien08
Hi, i have had this exact problem too only with MW3. It's been a problem since at least 1.5 months. (not sure because i didn't play the game for a few months before that). But before the game ran perfectly smooth on my B580. Other people have had this issue aswell.  Since i first encountered the problem there has already been like 4 driver updates yet the problem remains.
SSHEHAN
I have the same issue on a B580 graphics card. Only started when I downloaded the graphics software.
Gabriela_Intel
Thanks all for chiming in. I just wanted to let you know that we are already aware of this issue and are actively looking into it. We'll provide an update here once we have something to share.
Gabriela E.
Slang
Gabriela_Intel
Sorry I don't have an update I can share at this time.
Gabriela E.
