Intel® Arc™ Discrete Graphics
3512 Discussions
Can only use 90hz in SteamVR with PSVR2
anaheim13duck
Hey i can only use 90hz mode in SteamVR with PSVR2.
I can enable 120hz but when i than restart SteamVR it is reseted to 90hz.
I already changed my DP Cable to a 2.1 version and did a clean install of the newest driver 32.0.101.6449.
Unpluged all, restarted everything and tried again multiple times, still the same issue.
I have a ARC a770 graphic card and use Windows 11 23H2 with PSVR2 Adapter.
DeancR_Intel
Hi anaheim13duck,
Thank you for posting in the Community!
Please share more details about the issue so I can assist you effectively.
  • A clean driver installation using DDU in safe mode is recommended. Follow this link for instructions.
  • You could also test using the latest non-WHQL driver. This driver goes through all Intel quality assurance processes and is safe to use for evaluation.
  • Is this working before? When did the issue happened?
Dean R.
anaheim13duck
No it never worked.
I tried the clean install too, no change.
I don't even know if it is supported for my ARC a770, should 120hz work?
As i said i can select it but after SteamVr restart it is set back to 90hz.
What additional infos do you need?
ACarmona_Intel
Hello anaheim13duck,
Thank you for the response.
Based on my investigation, VR is not supported on Intel® Arc™ A-Series (A770) and B-Series GPUs.
For your reference, please check out this link:
To summarize, the Arc A770 does not support VR, so VR features may or may not work on your system. This is the main reason why you are unable to use 120Hz mode in SteamVR with PSVR2.
Carmona A.
DeancR_Intel
Hi anaheim13duck,
Dean R.
DeancR_Intel
Hi anaheim13duck,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
