Intel® Arc™ Discrete Graphics
4066 Discussions
Desktop Freezing - black screens and blue screen
Bandit8623
New Contributor III
latest driver getting random black screens on all monitors.  mouse freezes and then all screens go black then normaly come back.  this time about the 5th time its happened today it froze then blue screen.
This only happens when on desktop browsing the web
Stop code Video_TDR_Failure
During gaming im not getting any freezes or black or blue screens.
RedCapsicum9
New Contributor II
Arc Control sometimes loses its ability to check for updates. There are already about a dozen threads on this topic, and it still hasn't been resolved. The usual recommendation is to uninstall using DDU in safe mode and then install the latest version after rebooting. Personally, I find that DSA works better in this regard. Additionally, Windows Update occasionally downgrades drivers mistakenly, so it's worth keeping an eye on that as well. If you don't mind, could you also check if all TDR values are correctly set in your system registry? You can refer to this MSDN article for more details. If the issue persists, I recommend uploading a memory dump to OneDrive (or a similar service), and ensure it's at least an "Active Memory Dump."
Bandit8623
New Contributor III
im not using arc control.  i have latest drivers.  drivers from a month or so ago now dont have arc control.
i did ddu again and installed drivers again so far so good. ill update if it happens again
thx
Bandit8623
New Contributor III
i had manually disable all audio devices from my monitors because when changing adaptive sync on and off windows kept changing my audio device.
yesterday i enabled all audio devices on monitors that are connected to arc card and i havent had a blank yet. so possibly a bug tied to intel gpu audio.
ill update if that changes.
Bandit8623
New Contributor III
darn just had it happen again.  out of ideas,  but buggy drivers
Bandit8623
New Contributor III
windows dump attached.  6632 driver.  same happened on 6634
