This is a very strange issue, which I've been trying to fix for a while now. My hardware and software combination is quite unusual, so I would appreciate any assistance that can be given.
To preface this, my specs:
CPU: AMD Ryzen 5 8600G
RAM: 2x16GB Corsair Vengeance DDR5-6000
GPU: Intel Arc B580
OS: CachyOS (Arch-based), latest version
Drivers: xe driver, with mesa and linux-firmware-intel installed
My PC is running Arch, which is not Ubuntu, the main distro supported by Intel themselves, so I'm using the latest xe driver for arch instead. I have already tried the i915 driver, and my issue has not been resolved.
When playing X-Plane 12 (latest version, and latest beta) there are strange diagonal lines that appear on all 2D textures. It's difficult to describe, so I've attached some screenshots:
The two top screenshots depict this issue in the menus, where you see very regular diagonal glitches. The bottom two show this error in-game, where the glitches are more erratic and move and flicker - potentially because the in-game textures are changing and moving.
I don't see this issue in any other games, whether Vulkan (like XP12) or OpenGL. Changing graphics settings doesn't appear to help.
I'm really at a loose end here. Any support would be very helpful at this point.
Noting also that I have both asked for help in the X-Plane Community Discord, where they were unable to resolve the issue, and submitted this as a bug report to Laminar Research, the creators of the game, but they have not got back to me yet, and I doubt they will for quite a while yet.
Hello HippoProgrammer,
Thank you for raising this concern with us. Upon reviewing the image you provided, I can clearly see the diagonal lines you mentioned.
To further investigate, could you please share the following details:
- Have you tried running the game on Windows OS?
- What is the exact driver version installed?
- Does the issue only occur in X-Plane 12?
- Where did you download the game from?
To further assist you, I kindly request that you download and execute the Intel System Support Utility (SSU) in order to provide me with a complete system specification, which will enable me to assist you in reviewing your system information.
When the download is complete, launch SSU.exe.
1. Scan: Check the box Everything.
2. Click Scan.
3. Review: When finished scanning, click Next.
4. Click Save.
John M.
To answer your questions:
1. Yes - I used to use Windows 11, and there the game was running flawlessly without these diagonal glitches. I was always using the latest WHQL certified Intel Arc drivers.
2. I am unsure at this moment as I am not at my PC. I can get you the precise version number later if needs be, but it will be the latest version of the 'xe' driver provided in the mainline Linux kernel (version 7.0.3-1).
3. Correct.
4. Steam.
As per your request to download your Support Utility, I am unable to natively run the SSU as it is a Windows executable. Could you please confirm whether it is OK to run this tool through Wine or a similar compatibility layer, or whether I can manually provide the requisite system information to you?
HippoProgrammer
