Intel® Arc™ Discrete Graphics
4045 Discussions
Driver versions 7026+ will cause the dwm.exe to use excessive CPU
WEmwuZ
1.This issue occurs in the latest driver version include 32.0.101.8132 and 8135 non-WHQL.
2.This issue can be reproduced.
3.When i start play Valorant-CN Version or Delta Force-CN Version,it will 100% happend.
4.This issue does not occur in version 7026 WHQL.
5.My Game is download by WeGame.
6.I always use latest DDU to uninstall Display Driver
Please check it and fix it.
JedG_Intel
Hello WEmwuZ,
Thank you for posting on Intel Community Forum. I appreciate all the information that you shared so far and it will definitely help.
For me to investigate further, please share the additional information below.
1. Have you tried running these games without WeGame launcher?
2. What WeGame version are you using?
3. Does this happen with other WeGame games or only Valorant-CN/Delta Force-CN?
I look forward your response.
Best regards
Jed G.
WEmwuZ
1.Yes,its also appears in games that are not launched by WeGame.
2.My WeGame Version 6.1.2.9172
3.I dont know. I guess its a bug with Anti-cheat Expert (ACE) System
WEmwuZ
New situation
In 7026 WHQL, When I running the game , dwm.exe is working normally
But today i play the League of Legends-CN , dwm.exe is using a lot of CPU, causing lag.
I tried to Force Stop dwm.exe by taskmgr, when it is restarting, its bug disappeard . I cant reproduce it.
League of Legends also Download by WeGame
JedG_Intel
Hello WEmwuZ
Thank you for taking the time to share all this information. I understand that the 32.0.101.7026 driver initially worked well for you. However, based on the new details you've provided, it seems that the same issue might also occur with this driver. Could you kindly confirm if you're now experiencing the issue even while using the 7026 version?
Best regards
Jed G.
JedG_Intel
Hi WEmwuZ,
I'm checking to see if you're able to review my previous post. Kindly inform me if you need further assistance for me to proceed accordingly.
Jed G.
JedG_Intel
Hello WEmwuZ,
Jed G.
