Intel® Arc™ Discrete Graphics
3509 Discussions
Dune Awakening game crash
Darcoolio
I have a problem with Arc A750 and Dune Awakening.
I have constant crashes, sometimes during gameplay, but most often in armor customization menu.
I already tried with integrity of game files through Steam, updating graphic driver and complete game and system reinstall.
My configuration is:
Arc A750
B550
32GB ram
Any help would be fine.
lily_1
Hi @Darcoolio,
This looks like a stability issue between Dune: Awakening and current Arc drivers. Try the following:
Update to the latest Intel Arc driver (or roll back to 538x) if crashes started recently.
Disable XeSS or other upscaling options — these can cause instability.
Run the game in DirectX 11 mode (-dx11 launch option).
Check that Resizable BAR is enabled in BIOS.
Ensure Windows and BIOS are fully updated.
If crashes persist, submit a report via Intel Graphics Command Center → Feedback, including crash logs.
It’s likely a driver compatibility issue Intel is already reviewing for Arc GPUs.
Darcoolio
It is happening since august, so no new driver options did any good.
But i can try to disable upscale, so i will let you know.
Darcoolio
I guess that this helped.
I really hope that you will fix this, because XeSS upscale looks best in my opinion.
