Very bad stuttering and frame rates up and down all over the place in Tarkov.
Latest Driver 8331 also tested 8347.
Rolling back to 8132 and will test again, if this doesn't work I will test on a RX6600.
As this will confirm Driver and card issues.
B580 - 15% - 25% - 100% up and down, strange behavior.
CPU - AMD - 5600 @ 4.3mhz. - 72c.
32GB - 3200mhz.
HDMI - 1080p - 60fps.
Hello KoN,
To address the issue effectively, please share the information below.
1. What resolution and refresh rate are you playing at?
2. What in game settings are you using?
3. Does stuttering happen immediately when launching the game?
4. Do other games run smoothly on your system?
5. Which game distribution platform are you using (Steam, Epic Games, etc.)?
Additionally, to have a better understanding of your system configuration and components please generate a complete copy of the System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
Res = 1080p @ 60.
Low settings in game.
No, over clocks.
Card isn't running at 100% or even close. Sometimes runs at 35%
Seems the card with latest driver 8331 has gone back to CPU over head .
