Intel® Arc™ Discrete Graphics
4411 Discussions
Exiting application with exit code: 1. Updating driver.
Scafatiello
Every single time i tried to update Game On driver in the past year it gave me this error. After this i always need to restart the sistem, re-launching the same pre-installed .exe (in this case gfx_win_101.8826.exe but it doesen't matter wich one is it) and then it finally works. But if i don't restart the sistem it's always like this. Please fix. I'm attaching error log.
Nikhil_Intel
Hello Scafatiello,
I hope you are doing well.
Thank you for your response, and please accept my sincere apologies for the frustration this experience has caused you. I completely understand your frustration. You explicitly stated you have always had Resizable BAR enabled. After reviewing your SSU log file, here is an explanation of what is happening with your i7-9700K setup:
  • Compatibility: Intel Arc graphics cards require a 10th Gen Intel Core processor or newer to be supported. Because the i7-9700K is a 9th Gen processor, your configuration is considered unlisted.
  • For configurations not listed in our compatibility guide, there may be ongoing performance or stability issues. In your case, this instability is occurring during the software installation process, where the installer detects the 9th Gen platform and stops with an error.
  • Other users running Arc graphics cards on 9th Gen motherboards have reported similar installation limitations because the installer applies strict validation on unlisted configurations, even when Resizable BAR is enabled.
Because this hardware mismatch may continue to cause installation and stability issues, I highly recommend upgrading to a supported 10th Generation or newer processor for optimal performance.
Thank you for your patience and cooperation.
Nikhil
Nikhil_Intel
Hello Scafatiello,
Thank you for posting your query on the Intel Community Forum!
I sincere apologies for the frustration this driver update loop has caused you over the past year.
Your error log shows that a corrupted legacy background service IntelGFXFWupdateTool Tool from an older driver version is blocking the update and causing Exit Code: 1. To fix this permanently so you no longer need to reboot and reinstall every time, please follow these two steps:
1. Perform a Clean Installation Using DDU
Use this official guide to completely wipe the corrupted remnants before running your new installer: Intel Guide: How to Use Display Driver Uninstaller (DDU)
2. Share your SSU Log
Once the installation is complete, please generate a system log so we can verify the fix: Intel® System Support Utility for Windows*
  • Important: Open the utility, click scan, and ensure the "Network" box is unchecked before saving the log.
Once I receive the requested information, we will review the logs and determine the appropriate next steps.
I appreciate your cooperation and look forward to your response.
Nikhil
Scafatiello
I'll do it right now. Hoping for the best.
But keep in mind that i have tried in the past already to use DDU and performed afterwards a clean installation but the error was still there.
What happens is: i have an old driver installe --> i download newer Game On driver --> select new installation remove oneApi, computing program and auto update thing and leave only driver itself and intel graphic software. At the end i get the error.
Francesco
Scafatiello
Ok. I performed clean installation after using ddu. Had no issues But as I said this error appears only when i update the driver having one already installed. I'm attaching SSU report for details as you needed.
Nikhil_Intel
Hello Scafatiello,
Thank you for providing the Intel SSU log. I completely understand your frustration that this driver update issue has persisted over the past year, especially since you have already attempted clean installations with DDU.
While analyzing your hardware configuration log to find a permanent solution, data flagged a critical platform bottleneck that is severely impacting your system. Please find the essential fix outlined below:
Enable Resizable BAR (Critical Performance Fix):
The log reveals that Resizable BAR (ReBAR) is currently disabled on your system. Your Intel Arc A770 strictly requires ReBAR to function optimally. Without this feature active, your graphics card is experiencing massive performance drops (often 20% to 40% lower FPS) and severe stuttering in modern games.
To correct this and ensure your hardware communicates properly:
  • Update Motherboard BIOS: Your ASUS PRIME Z390-A motherboard is running an older BIOS (Version 2004 from 2021). Please visit the official ASUS support site, update to the latest available BIOS version, and ensure CSM is disabled (pure UEFI mode).
  • Enable BIOS Settings: Once updated, enter your BIOS menu, navigate to the Advanced settings, and enable both Above 4G Decoding and Resizable BAR Support (set to Auto/Enabled).
Prioritizing this motherboard BIOS adjustment is highly recommended, as it will unlock the true gaming performance and stability of your graphics card.
Please let us know if you have any questions or require further assistance with these settings.
I appreciate your cooperation and look forward to your update.
Nikhil
Scafatiello
I have no idea what section in the “log reveals that Resizable BAR (ReBAR) is currently disabled on my system” cause I have it turned on…
Nikhil_Intel
Hello Scafatiello,
Thank you for your update.
I understand that Resizable BAR was previously enabled on your system. However, please note that whenever a BIOS update is performed, the system settings are automatically reset to default values.
Due to this, features such as Resizable BAR (ReBAR) may get disabled after the BIOS update, even if they were enabled earlier.
I kindly recommend you to:
  1. Enter the BIOS settings
  2. Navigate to the PCI/Advanced settings section
  3. Ensure that:
  • Above 4G Decoding is enabled
  • Resizable BAR Support is enabled
After re-enabling these options, please save the changes and reboot the system. This should ensure that Resizable BAR is active and functioning as expected.
Nikhil
Nikhil_Intel
Hello Scafatiello,
I’m writing to follow up regarding the Resizable BAR (ReBAR) configuration on your system. I would like to check if you had the opportunity to access the BIOS settings and re-enable the required options:
  • Above 4G Decoding
After applying these changes and rebooting the system, please let me know if Resizable BAR is now functioning as expected.
If you are still facing any issues or need assistance navigating the BIOS settings, please don’t hesitate to reach out I’ll be happy to guide you further.
Looking forward to your update.
Nikhil
Scafatiello
I'll try to be more clear, hoping your answers aren't automatically generated. i have always had resizable Bar enabled. Again, i have no idea what made you believe that i had it disabled in that log file. Anyways I still cannot comprehend how this setting has anything to do with the issue i'm facing. For the sake of clarity i did eventually update BIOS yesterday after you pointed out i was using an older version for my motherboard and i did re-enable REBAR. But still cannot comprehend... " ".
Finally, I'll just say that I won't be continuing with the troubleshooting: from now on, I'll limit myself to reporting new bugs and inaccuracies on this forum. I don't think it's up to me to figure out what's wrong and try again and again until it's clear.
From now on i'll be lowering my expectations on the support you provide via the forum. Incidentally, and this is where I'll really end, I made a similar post on Reddit and found feedback from other users experiencing the same problem.
Thx for consideration.
Francesco
Nikhil_Intel
Hello Scafatiello,
Nikhil
Scafatiello
Thanks for the clarification, I'll accept this as a "solution" and close the thread
