Intel® Arc™ Discrete Graphics
4045 Discussions
Experiencing stutter while playing Minecraft
XiaoLuo
Débutant
13 259 Visites
Hi, Intel team,
Recently I have been experiencing unpleasant gaming experience on an Arc A750. My system information are provided below.
I am playing a modded minecraft, ver 1.20.2, fabric with 2 graphic optimizing mod called sodium and iris. When I first launch the game, the A750 can run smoothly to 120fps However after a while, the game become laggy, the frame rate would drop all the way to a single digit. (screenshot is attached). But my pc was not experiencing any overheating that would cause a performance issue. And after I have restart my game, the frame rate goes back to normal and appear again as I continue my game.
Please help me with this problem.
Yours sincerely,
XiaoLuo
Étiquettes (3)
0 Compliments
10 Réponses
XiaoLuo
Débutant
13 250 Visites
Here is the log of Minecraft I found.
0 Compliments
RamyerM_Intel
Modérateur
13 197 Visites
I'm sorry to hear about your unpleasant experience. Thank you for sending us the logs in your game. For now , we will be coordinating this with our team for further checking. I will give you an update once I receive it on or before January 26, 2024.
Ramyer M.
0 Compliments
XiaoLuo
Débutant
13 168 Visites
Thank you very much for the update Ramyer, I look forward for your reply.
XiaoLuo
0 Compliments
Catulpos_Intel
Employé
13 132 Visites
Hello XiaoLuo,
Thank you for the patience you’ve exhibited as you wait for our update.
We thoroughly checked this with our team, and we want further information from the issue you reported so we could provide you with an accurate recommendation that may resolve your issue.
  • What steps did you take to troubleshoot the issue?
  • Per checking, we can see that your graphics driver version is 31.0.101.5085 however, the latest version we have is 31.0.101.5186_101.5234 WHQL Certified. Hence please be advised to update your graphics driver. Link: Intel® Arc™ & Iris® Xe Graphics - Windows*
  • Is Re-BAR enabled? If not, please enable it for optimal performance.
  • What is the brand, model, and wattage of your power supply?
  • When did you first encountered the issue?
  • Did the game run smoothly before?
  • Any hardware or software changes made on the system before the issue occurred?
  • Is this the only game that has this issue?
Please let us know of the outcome and looking forward to your response.
Catulpos_Intel
0 Compliments
XiaoLuo
Débutant
13 083 Visites
Hi Catulpos,
Thank you for your prompt reply. I took a day to test if the same issue appears again on the new driver (31.0.101.5085) Unfortunately, the new driver did not solve the issue.
I first checked the Task manager, the GPU load is normal, about 80%-90%. Then checked the temperature and power consumption of my PC and everything was fine, except GPU core was taking about 60W of power.
XiaoLuo_0-1706381275379.pngSo I assume it is a software issue and I gathered those log that I have uploaded earlier in this discussion.
For your information,
- Resize bar is enabled
- Power supply unit is a Thermalright TG-750-W
- I first encountered the issue after I just install the game and about 1 hour of playing
- The game would run smoothly at the start about 120 fps, but after a while it will start to lag, the game FPS would drop to about 20 fps.
- I am not sure about if it's hardware or software change that cause the problem, but the game would run smoothly on my laptop. (I did install Intel CAS. But I do not know if that cause the problem)
- Minecraft Java Edition (Fabric 0.15.5 with mod Iris Shaders 1.6.14 and mod sodium 0.5.5) is the only game that I have experience sudden stutter.
Once again, thank you for your help.
Yours sincerely
XiaoLuo
0 Compliments
RamyerM_Intel
Modérateur
13 081 Visites
Thank you for your prompt response. We do have one more step you can take, kindly please try the following:
  1. Turn off the Windows Game Bar and Game DVR.
  • Press Windows + S.
    • In the Windows search box type Game bar settings and press Enter.
    • Under Control how Game Bar opens and recognizes your game turn off the option for Record game clips, screenshots and broadcast using Game bar
    • From the left had menu, directly below Game Bar, select Game DVR.
    • Turn off the Record in the background while I’m playing a game setting.
As a reference for this troubleshooting step you may check this link: https://www.intel.com/content/www/us/en/support/articles/000032169/graphics.html
If the issue still persists, kindly please send us the following details so we can investigate it further
  1. screenshot of the game settings of your Minecraft
  2. .txt file of the DirectX Diagnostic Tool (dxdiag)
  3. Screenshot of your internet speed. You may use this link:https://www.speedtest.net/
Ramyer M.
0 Compliments
RamyerM_Intel
Modérateur
13 011 Visites
Hi XiaoLuo
I am just looking for an update regarding the troubleshooting steps I have suggested. Is everything working well in your end?
Ramyer M.
0 Compliments
RamyerM_Intel
Modérateur
12 847 Visites
Hello XiaoLuo,
I hope everything has worked well in your end. As we have not heard a response in the past few days, we will proceed in closing this case. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Ramyer M.
0 Compliments
xSkullzZ
10 636 Visites
Hi, I'm replying to this post to not open a new one, but I'm experiencing the same problem with my setup as well.
I get smooth fps for the first 1-3 hours, and it's start to drop significally until it reaches eventually 0:
GPU usage is in the norm (60-70%) and it starts to go down as the fps go down and become inconsistent (15% to 100% and back to 20%).
I tried every optimization possible and I cranked settings to the bare minimum in both render distance, render simulation and details, but still this occurs.
I'm using:
  • Embeddium
  • Embeddium++
  • Distant Horizon
  • MemoryLeakFix
  • ModernFix
  • Radium reforged
  • FerriteCore
  • ImmediatelyFast
It seems like a problem where the VRAM get saturated overtime and never get flush because sometime I get OUT_OF_MEMORY crashes. Doing researches I found out that it could also be a OpenGL problem, but I don't know if there is a fix for this, or your team is working on a fix for improving OpenGL compatibility.
Further information about my rig and game settings:
  • 64GB of RAM (30GB dedicated on Minecraft, more than enough)
  • Ryzen 9 7950X3D (barely touches 25% during extreme sessions)
  • Resizable Bar is enabled
  • I've excluded mods because even Vanilla has the same problem.
  • I don't remember exactly the PSU at the moment but it is an overkill 1200W 80+ Titanium, so more than enough for the GPU
  • Minecraft Java Edition 1.20.1 with Forge 47.3.0
I hope that this is enough to understand the problem, thank you for your help.
0 Compliments
Aarontoffel
Débutant
9 895 Visites
It's because u have resized bar enabled.. disable it
0 Compliments
Répondre
