Intel® Arc™ Discrete Graphics
3582 Discussions
Fan & Thermal Tuning (ARC B580) Problem
MrCell
EDIT: Moved to non gaming section.
https://community.intel.com/t5/Graphics/Fan-Tuning-ARC-B580-Problem/m-p/1674111#M139812
Problem:
Fan curves not working: | Off | Basic | Advanced |
Temps: GPU 25c / MEM 26c
Curve: <49c 0% | >49c 30%
The problem:
OFF: Fan jumps from 0rpm to 170rpm 700rpm Constantly and the card is only 25c.
Basic: 25c 0rpm - 700rpm
Advanced: Temp 25c Manual fan curve. Under 55c 0% 55-60c 30%(RPM Still Jumps around).
1. Card: Sparkle Arc B580 Titan OC Firmware (23.0.1051) (ReBar)
2. DDU / Revo has been used.
3. Everything is Updated (Windows,Drivers,Etc) - (32.0.101.6647)
DhannielM_Intel
Hello MrCell,
Thank you for posting in the community, I have seen the other post and downloaded the images and text file that you have included on that to serve as supporting information. Though I just wanted to clarify the issue that you are having on this matter. Based on my understanding, whenever you are setting the fan curve on Intel Graphics Software, the fan speed does not follow the setting you set? Then the speed became inconsistent even though it was set in the setting how much rpm should be on range of temperature? Can you tell me if my understanding to this issue is correct? This will help better understand the situation and further investigate this issue.
Dhanniel M.
DhannielM_Intel
Hello MrCell,
I'm following up on my previous inquiry for clarification regarding this issue. Gathering more detailed information will help us provide an appropriate solution.
Dhanniel M.
MrCell
DhannielM_Intel
Hello MrCell,
I understand, and it seems you're already progressing with the other thread. Would it be alright if I close this one? Please let me know, so we can consolidate everything into a single thread.
Dhanniel M.
DhannielM_Intel
Hello MrCell,
I wanted to ask if you prefer to continue receiving support in this thread or the other one. Please let me know which option you'd like to proceed with.
Dhanniel M.
MrCell
let's close this thread.
Thanks for the support.
DhannielM_Intel
Hello MrCell,
Thank you for confirming. I will proceed with closing this inquiry so that you and the representative can focus exclusively on the other thread.
Dhanniel M.
