Intel® Arc™ Discrete Graphics
4154 Discussions
Final Fantasy 13 crashing
P4C3MAK3R
Hallo, i just changed my gtx 980ti to arc 770lm. My FF13 keep crashing early-mid gaming.
I have tried everything, it keeps crashing. I just upgraded my pc fresh, formatted my drive, and installed windows 11 new.  I went from nvidia gtx980ti to arc 770lm. FF13 played fine on 980ti.
My PC spec :
MSI Pro B660 Mainboard, Intel 13600, 16GB DDR4, 750W Corsair PSU, SSD HD.
The Game keeps crashing about after 5-15 min. gaming, usually on battle or cinematic.
I tried both Beta and WHQL driver with clean installation, both don't work.
It keeps crashing no matter which resolution (tried HD, WQHD, UHD).
I tried to change my desktop resolution also don't work.
Does someone have solution to this problem?
Andres_Intel
Hello P4C3MAK3R,
Thank you for posting on the Intel communities. I am sorry to hear that you are having game crashing issues with your Intel® Arc™ A770 Graphics, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
P4C3MAK3R
The issues started right after i installed the game and play it. The crash happens 5-10 minutes after i start the game. Btw i also reported this in report a bug or issue in intel graphic command center. I attached the files needed.
rgds.,
Michael Halim
Andres_Intel
Hello P4C3MAK3R,
Thank you for your response, it has been really helpful.
Please follow the steps below and let me know the results:
Andres P.
P4C3MAK3R
I have updated the BIOS and the latest beta driver. I tried playing at 1080p windowed version (HDR turned off, lowest aliasing and lowest shadow) and it seems to be stable for about 20 minutes gameplay. Then i tried played at full screen 4k (with HDR), it still crashed after about 10 minutes gameplay.
Andres_Intel
Hello P4C3MAK3R,
Thank you for your answer, all the information provided has been very helpful.
I will start with an investigation of this issue, as soon I have further information I will let you know.
Andres P.
Andres_Intel
Hello P4C3MAK3R,
We have been working on the investigation, to e able to continue with it please follow the steps below:
Let me know if the issue persists.
Andres P.
P4C3MAK3R
Hallo,
i use steam to download the game.
The problem still persist. I have clean installed both drivers using Display Driver Uninstaller.
I dont know if this info useful or not. The game last longer in 1080p windowed, at 4k it crashes quicker maybe after 3-5 battle (or a long boss battle). But eventually at all resolution it will crash no matter what.
I will try to install the latest beta driver and try to play again at 1080p windowed mode.
rgds.
Michael
Andres_Intel
Hello P4C3MAK3R,
Thank you for your answer, it has been really helpful.
I will continue with the investigation, as soon I have further information I will let you know.
Andres P.
Andres_Intel
Hello P4C3MAK3R,
We still working on the investigation, while we work on it, please let us know the results of the latest beta driver at 1080p windowed mode.
Andres P.
P4C3MAK3R
It still crashes. but at lower resolution it takes a bit longer to crash than in higher resolution. About after 7-8 battle, and usually at the ending of the battle where the screen should switch from battle to walk around mode.
rgds.
Michael
Andres_Intel
Hello P4C3MAK3R,
Thank you for your response, and for completing the steps.
I will continue with the investigation and I will try to reproduce the issue, as soon I have further information I will let you know.
Andres P.
Andres_Intel
Hello P4C3MAK3R,
Thank you for your time.
We sill working on the reproduction of your issue, we will let you know the results as soon as possible
Andres P.
Andres_Intel
Hello P4C3MAK3R,
We have been working on the investigation and we were able to reproduce the issue with the latest BETA driver version 31.0.101.4499. When we tested the latest stable driver version 31.0.101.4502 released this week, in our system the issue disappeared.
Just to make sure that your system has the same behavior, please follow the steps below:
Keep us informed of the results.
Andres P.
P4C3MAK3R
i have installed the lastest driver. And i am pleased to inform you that at 1080p full screen the game seems stable enough. It does not seem to crash till now (have been about 1 h in game). But it still crash at 4k resolution (after about 5-10 minutes in game). Any thought why the game still does not hold at 4k?
rgds.
Michael
P4C3MAK3R
Uff it still crashes, even at 1080 p.
rgds.
Michael
Andres_Intel
Hello P4C3MAK3R,
Thank you for your response, all the information provided has been really helpful.
We will continue with the investigation, and as soon I have further details, I will let you know to answer all you questions.
Andres P.
Andres_Intel
Hello P4C3MAK3R,
Thank you for your time, we still looking into this.
We are trying to reproduce the issue and now we have a question, does this issue happen in a specific area or time of the game?
Andres P.
P4C3MAK3R
It happened almost always during the battle, but after the driver update (4502) it happens at any time without warning. Just suddenly get kicked to desktop in windows. I will try to install the latest driver (4514) and try it again.
rgds.
Michael
Andres_Intel
Hello P4C3MAK3R,
Thank you the clarification.
I will wait for you to test the driver 31.0.101.4514. Please let us know the results.
Andres P.
P4C3MAK3R
Hello, it still crashes, i tested it at 4K, because at 4k it takes shorter time to crash. At 1080p it must be more stable and should take longer to crash. So i prefer to test it at 4K to get quicker result.
rgds.
Michael
