Intel® Arc™ Discrete Graphics
GPU problem?
Arvind3
Is it a GPU problem or something else? I'm seeing that glowing red and blue pixelated screen while playing this game before it was not a problem it started happeing today only. im using ARC B580.
JedG_Intel
Hello Arvind3,
To address the issue effectively, please share the information below.
1. Does the pixelated screen appear only in Apex Legends or other games too?
2. How long into gameplay does it typically appear?
3. Does the issue happen immediately at game launch or after playing for a while?
4. Did you make any recent changes to the system before the issue appeared today?
5. Which digital distribution platform are you using? (Steam, Epic Games, etc.)
6. Kindly share the exact game settings you are using.
Additionally, to have a better understanding of your system configuration and components please generate a complete copy of the System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
Arvind3
So far I've seen mostly seen it in Apex Legends. there were some graphic issues when i was playing Hogwarts legacy it also sometimes pixalated and Assassin's Creed Shadows also had some graphics issue but not pixelated.
In Apex Legends,  whenever i get into a match it appears pixelated. I reverted back to older version of the driver; it solved some problem but not entirely. still some pixalted apears not as much as the previous picture i uploaded but its still there. i am on steam platform.
I am uploading SSU report below.
JedG_Intel
Hi Arvind3,
Thank you for sharing all this information. To look into this further, could you please provide the System Support Utility (.txt) file? This will allow me to review all the details captured in the report.
Best regards
Jed G.
Arvind3
I'm uploading the file below
JedG_Intel
Hi Arvind3,
Thank you for providing the SSU file. After reviewing it, I noticed that the BIOS version on your system is quite outdated. Please try installing the latest BIOS version 7E80v1A40. If the issue continues after the update, please let me know and I’ll investigate further.
Best regards
Jed G.
Arvind3
I updated my BIOS, as you mentioned. But unfortunately it still didn't fix the issue.
JedG_Intel
Hi Arvind3,
Thank you for taking the time to update the BIOS. Since the issue is still occurring, I will continue investigating further. To help with the replication I will be conducting, may I know which digital distribution platform you are using? Additionally, could you please share the steps you follow to recreate the issue?
I hope to hear from you soon.
Best regards
Jed G.
Arvind3
I’m playing the game on the Steam platform. There aren’t many steps involved — I just launch the game and queue for a match.
When the match loads, I notice the following issues:
  • On one map, I see red and blue pixel artifacts on the map World edge.
  • On the Broken map, the floor textures appear heavily pixelated.
  • The third map I tested seems fine.
I’ve already shared my in-game graphics settings previously.
Thank you
Mike_Intel
Hi Arvind3,
Thank you for the update.
Upon checking the SSU, your Graphics driver version is 32.0.101.8250.
The latest driver available is version 32.0.101.8509.
Please install the latest driver using DDU and update this thread if there's any changes.
Kindly refer to the link below for the steps on how to install DDU and the direct link of the driver.
How to Use the Display Driver Uninstaller (DDU) to Uninstall a...
Intel® Arc™ Graphics - Windows*
Michael L.
Arvind3
I am experiencing a graphics issue in Apex Legends while using Intel integrated graphics.
When I install the latest graphics driver, the gameplay becomes worse. On the World’s Edge map, I get large red and blue pixelated textures, and the issue is very noticeable and not playable at all.
Because of this, I rolled back to an older driver version. With the older driver, the large red and blue artifacts are gone, so performance is more stable. However, I still experience a pixelated or broken floor texture on the map.
Thank you
Arvind3
Hi
sorry i didnt meant to say  Intel integrated graphics in the previous message im using Intel Arc B580.
thank you
Arvind3
Hi
Sorry, I didn't mean to say Intel integrated graphics in previous message i am using Intel Arc B580.
Thank you
JedG_Intel
Hi Arvind3,
Thank you for explaining the issue in detail. I would like to share that Intel released a new driver version 32.0.101.8531. Please try to perform another clean installation using DDU. If the issue is still observed, please let me know so that I can proceed further with the investigation.
Best regards
Jed G.
Arvind3
i have already tried with new driver and unfortunately i still have the same issue so I'm again using the older version so that at least its playable.
Thank you
JedG_Intel
Hi Arvind3,
Thank you for continuing to follow our recommendations. I will investigate the issue further and also attempt to recreate it in our test lab to see if I can observe the same behavior. I’ll provide you with an update as soon as possible.
Best regards
Jed G.
Arvind3
hi,
thank you so much for looking into it.
Zach_Intel
Hello @Arvind3
There has been a new driver release, version 101.8860, that appears to resolve this issue. Would you please perform a clean install on the most recent graphics driver and let me know if it resolves your issue?
