Intel® Arc™ Discrete Graphics
3508 Discussions
HDMI NOT DETECTING
UmerAhmed
GUYS PLEASE SOMEONE HELP ME MY HDMI IS NOT WORKING IT IS NOT DETECTING I UPDATED THE DRIVER I DISABLED IT AND ENABLED I DID EVERYTHING UPDATED BIOS AND NOW MY ONLY HOPE IS YOU GUYS I HAVE
11th Gen Intel(R) Core(TM) i7-11800H
INTEL UHD GRAPHICS
AlHill
First., do  not be afraid to release the CAPS LOCK.
Have you tried a different HDMI cable?
Have you inserted a graphics card?
The latest driver can be found here:
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[W10 is this generation's XP]
UmerAhmed
here you go
