Intel® Arc™ Discrete Graphics
4065 Discussions
HP Elitebook w/Intel Iris Xe
DanKone
is there any way to force the Active signal mode to match the desktop mode? The second display cannot take the 2560x1600 it is sending. I changed the desktop mode to 1920x1080 but the active signal remains the same.
 Thank you for any assistance you may have.
RandyT_Intel
Hi @DanKone,
  • Please provide the SSU log report and share it here so I can review your system's configuration.
  • What type of connection are you using (HDMI, DisplayPort, USB-C, VGA, DVI)?
  • What is the make and model of the second display?
  • What is the maximum supported resolution of your second display?
  • Are you using any adapters or converters in the connection chain?
  • Did this setup work previously with the correct resolution?
  • Were there any recent system updates, driver changes, or hardware modifications?
  • Have you contacted HP support regarding this display resolution issue? If so, what troubleshooting steps or solutions did they provide?
Randy T.
DanKone
Thanks for reaching out Randy. Sorry for the late response. I have been out of the office.
I am from a higher education institution. the second displays vary throughout our location based on the room the instructor is in. I was doing testing on a LG86US340C0UD. In our testing the only way for the content to display properly is to send it through a secondary scaler. Kramer VP451. There are only a small handful of instructors that have this series of laptop with this particular Iris Xe graphics controller. Every other desktop and laptop allows us to change the display and active resolution to be the same. Everything here from displays to projectors run flawless on 1920 x 1280 60hz. It would not be financially reasonable to put in a scaler into every room (well over a hundred). 99% of the time it is an HDMI connection. Most cases it does travel through a switcher like an Atlona 601 or Kramer Dip31. Even with the Kramer dip31 having EDID settings, it cannot properly send 1920 x 1080 to the display. Only the more robust VP451 brings it where it needs to be. All other desktops and laptops are functioning with being able to chose 1920 x 1080 as the active resolution. I have not contacted HP. You are my first contact with anyone in trying to change the active resolution. I appreciate any assistance you can offer.
Thank you,
Dan Krauel
DanKone
sorry... typo here. Everything here from displays to projectors run flawless on 1920 x 1280 60hz.
        1920 x 1080
RandyT_Intel
Hi @DanKone,
I’ve reviewed the SSU logs and identified that your current Intel Arc graphics driver version is 31.0.101.4255, which is outdated. To resolve potential software conflicts and improve system stability, please follow the steps below:
Initial Recommended:
Clean Installation of OEM Driver
If Issue Persists: Use Intel Generic Driver alternative Version: 32.0.101.7029 (Intel generic). Repeat the clean installation process and reboot.
Important: Always perform a clean uninstall before switching driver versions.
Additional Troubleshooting
 Test with Different Cable or Connection Type
  • Helps rule out hardware-related display issues
Manually Set Active Signal Mode
Use Intel Graphics Command Center/Software to ensure display signal settings match your desktop configuration.
Steps:
  1. Open Intel Graphics Command Center
  2. Go to Display tab → Select active monitor
  3. Note current resolution, refresh rate, and color depth
  4. Access Advanced Display Settings or Custom Resolutions
  5. Set Active Signal Mode to match desktop settings (e.g., “PC Mode”)
  6. Click Apply → Confirm changes → Test for 30 seconds
Alternative via Windows Settings:
  1. Right-click desktop → Display settings
  2. Scroll to Advanced display settings
  3. Click Display adapter properties
  4. Go to Monitor tab → Ensure refresh rate matches monitor specs
If issues persist, consider rolling back to a WHQL-certified driver and document which driver version and settings combination resolves the issue for future reference. Let me know once you've tried these steps or if you need further assistance.
Randy T.
RandyT_Intel
Hi @DanKone,
I'm following up on the previous recommendation I provided. Have you had a chance to review the information and apply it to your system? Please let me know the outcome so I can determine the next best course of action.
Randy T.
RandyT_Intel
Hi @DanKone,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Randy T.
DanKone
Thanks Randy.... I did respond but mistakenly sent it back through the email notification, not here. I am still trying one last solution that I ran into a hiccup with. Using the 3rd party uninstaller of the driver. I require a bitlocker password which I have to get from mt IT department. I will resubmit once I try that. I appreciate all your assistance!
