Intel® Arc™ Discrete Graphics
3644 Discussions
INTEL SAYS MY CURRENT SYSTEM CONFUGARATION IS NOT SUPPORTED BY INTEL GRAPHICS SOFTWARE SO I CAN' USE
INFINITE1
I cant use  my intel graphics software app because it says something about unsupported system configuration and i cant fix it i need help
AlHill
Here are the published requirements for Intel ARC:
https://www.intel.com/content/www/us/en/support/articles/000091128/graphics/intel-arc-dedicated-graphics-family.html
Does your system meet these requirements, or not?
To remove the mystery, download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[W10 is this generation's XP]
INFINITE1
AlHill
Seems pretty clear to me.  This is your processor:
https://www.intel.com/content/www/us/en/products/sku/208922/intel-core-i51135g7-processor-8m-cache-up-to-4-20-ghz-with-ipu/specifications.html?wapkw=i5-1135g7
The ssu report says it has intel® Iris® Xe Graphics, not ARC graphics and does not have discrete graphics support.
I suggest that you check with ACER to determine if any other discrete graphics are included in their design.
