Intel® Arc™ Discrete Graphics
3488 Discussions
Important tips for Intel Arc graphics and software
addelucas123
New Contributor II
Good morning, First of all I want to congratulate you, I love the latest drivers, the fantastic software!!!, I am going to give several very important suggestions so that you can fix it and pass it on to the department corresponding to the drivers, but it is very important to do so, okay, I ask you please, I'm going to send some screenshots of a video okay, what I would like you to also implement is the Intel Arc A, We return to the same topic A310, A580 etc, There is something that Intel Arc A770 and other A750 models etc., that it does not have, for example
1 GPU Tuning: Basic or Advanced
2 VRAM Tuning: Compatibility also for other Intel Arc A310, A380 graphics etc.
3 Power limit: Very important If A770 GPU consume 225 TBP, Set 190 TBP
4 For example, in gaming, okay, I see that the B580 consumes 185w and 105w in games.
5 Well, practically the same B580 but on A770, for example if A770 consumes 192 in demanding games, well the same but consuming a little less if we can maintain the same 2400MHz frequency
6 Improve 1080p performance Intel ARC A770 10% / 1440p 15% or 20% performance improvements
7 Outperform Intel Arc A770 RTX 3060 Ti and 5% over RTX 4060
You see, for example, if the B580 consumes RDR2 in games, for example, which is the important thing and other games, as you can see, the B580 consumes 120w 1440p and higher frames, okay, Intel ARC A770, let's see if it might consume the same 120w, 125w okay, that's it. It is very important that you keep this in mind, okay, why do I say that because surely 99% of 71 degrees would go down to 60 degrees, which is what we are looking for and want I hope I have explained it well, I want you to try the Arc A770 but many tests
Remember that I still have the Intel Arc A770 16GB LE
Earl_Intel
Hi addelucas123,
Thank you for sharing your feedback regarding to the performance of our B580 Graphics Card!
Regarding to your recommendation and request, rest assured that I will further check this internally and will provide an update on this thread as soon as possible.
Earl E.
addelucas123
New Contributor II
Good morning, what I say the suggestion I give is that the Intel Arc A770 has the same function and the same temperature etc etc as the Intel Arc B580, I mean that's what I mean
RandyT_Intel
Hello addelucas123,
We truly appreciate your input and are committed to carefully evaluating these ideas to improve our products and services.
To set the right expectations, please note that we will need some time to review and address your suggestions. We will categorize them into groups such as feature improvements, user experience enhancements, and performance optimizations. Our focus will be on high-priority suggestions, especially those that have a direct impact on user experience.
Thank you once again for your valuable feedback.
Randy T.
