Intel® Arc™ Discrete Graphics
3512 Discussions
Indiana Jones and the Great Circle - Low GPU Usage - Intel Arc B580
Only30K
Hello, I got my B580 today and wanted to test it out on Indiana Jones. After meddling with the settings I cant get the fps to move at all. I tried Low, Medium, High presets. Fps stays on 30-35 no matter the settings in certain scenes for example the beginning jungle level before entering the cave and looking into certain directions in subsequent levels. GPU shows max 45% utilization and in some parts it spikes to 80% where it jumps to 60 fps. Is this a driver issue? Because when I saw benchmarks, I saw it running at around 50-60 on high-medium pretty stable in the same scenes I tried.
My specs are Asrock B450M Pro4, Ryzen 5 5600x, 32GB 3200Mhz RAM, Arc B580
Windows 10 Pro 22H2 and using driver 32.0.101.6253
The version of the game I am running is the Xbox Game Pass version - Indiana Jones and the Great Circle
REBAR is enabled so is above 4G encoding
It is running on PCIE 3.0x16 but testing other games I havent seen any noticeable performance losses, and even if, I dont think it should be anywhere near 50% performance loss.
I would appreciate any insight. Thank you in advance
B850
@Only30KI just tried to play the game and I have the same issue, using the latest drivers too. It's weird as the game does seem to run well in the in game cut scenes but when it goes back to player control the frames drop and the utilisation hovers around 40ish percent as you also noticed.
Running on an ASrock challanger OC B850
hlompton
I have the same problem with my B580. My CPU is a 5700X3d. I get around 25 fps in the beginning area of the game regardless of how low i set the resolution and the GPU usage is low.
addelucas123
New Contributor II
I'm still going to be very low, the performance is far below what Intel promises, DirectX 12 is supposed to perform well the Intel Arc A770 graphics and the new generation like the B580 because not even that, we're waiting for the Indiana Jones game to receive Intel XeSS 2, because it's already old generation and new either configuration whatever it is, I'm going to native 1440p 2K 30 to 45 FPS some zons 70 with 80 FPS peak, it means that the a770 and b580 graphics should at least play at maximum and move it without complication, Intel stability, because if I say that DirectX 12 is going better or Vulkan prove, Please Intel I have the same performance problem, in the jungle, where it loads a lot and other places fix that low fps, I have Arc A770 16GB, which should throw everything to the maximum at 60 FPS in 2K 1440p, if it were 4K I should throw 40 to 45 FPS approximately, I urgently need you to communicate to the game developers implement XeSS 2 , since it will be compatible 1 generation and 2 generation the old and the old one. new generation, put the pile on.
Pat321
Same thing here, max 32 fps
B580 LE
AMD 3600X
16G Ram
Win 11
1080P
Chipset X570
addelucas123
New Contributor II
Good morning, it happens to me the same but in resolution 2560x1440 that is 2K, update the drivers the latest version and continue with the
performance, there is area like the jungle, pyramid and other sites drop 30 FPS to 45 FPS, For me that is totally unplayable with the performance , I pass the video but that's unplayable.
https://youtu.be/MSH_j27WDRs?si=rrY8jtVcjLtrBJK0
