Intel® Arc™ Discrete Graphics
3563 Discussions
Intel ARC has difficulties to work on Alienware Ryzen motherboard
Mascready
Hello. I just received my Arc A770.
Beautiful design, really impressed by the work of art so far.
To test it out, I decided to install it on my actual rig : a Alienware Aurora R10 Ryzen Ed. (yes, I know...)
The Dell motherboard is a funny thing. The graphic connector (PCIe 4.0 x16) doesn't play well with this new card : no display output. The chipset is a B450A, an OEM B450 that have just a bit of PCIe 4.0 connectivity (graphic and NVMe SSD)
I logged via a remote desktop connection and "oh surprise" no device to be found. Impossible to install Intel drivers obviously.
So I plugged it in the second PCIe slot (3.0 x4) and... It worked ! It isn't the solution I was hoping for but good enough for now.
So now benchmarking it with 3dmark (sorry Intel) and I'll see if the PCIe bandwidth have a big impact on your card. My config : Ryzen 3600x with 32g of DDR4-3200 and nvme PCIe 4.0 So far, my machine managed to pull a decent score of 8987 in Time Spy (Worst result of the entire database).
My CPU seem to be a bottleneck : in this test, my CPU score decreased by 2%.
I can't wait to try it out in my future rig. Hoping that a good motherboard with a Ryzen 5800x (with SAM enabled) will solve the issue.
Until then, I would be very interested in suggestions on how to remedy this problem. Thanks for your time.
knarf
Patch your bios
I had issues on AMD MSI B550 where SVM (virtualisation) was stopping it boot.
Mascready
I'm using the last BIOS version but as I understand, my motherboard hardware version will not receive AGESA updates in the future so no Rebar / SAM.
I will try to disable virtualisation and I'll update you.
Thanks for the tip.
Edit : Didn't solve my problem. I'll reuse my GTX 1660 Ti for the moment and I'll wait for my new parts. Thank you again for your help.
Danrdz10103
Same thing here. I turned off all visualization and no luck! I Did not have an specific setting of SVM, so I just selected virtualization "disable" but it did not do anything. thanks for the suggestion.
Danrdz10103
wow I am facing the same issue. any chance you are using a Alienware Aurora Ryzen?
Mine 3800X wont show any video and I was begging to think it was the video cable so I just ordered a new one.
So is it not me? there is no hope to boot with the A770 on a Alienware Ryzen?
Mascready
Hey. Yes, I used a Aurora R10 Ryzen ed.
Found no solution. I think every piece of hardware is digitally signed. RAM is... Dell / Alienware is a trash company. And as said Intel during a Dell judgement "Dell is the best friend money can buy"
Danrdz10103
Thanks for the reply. I lost hope and I bought a NUC 12 extreme to use my A770. So far going great.
now I need to find someone who wants to buy this Ryzen 3800X Aurora R10.
Mascready
Totally in the same case ...... 7ngxra1kawez1
Carlos_L_Intel
Hi @Mascready
Thank you for posting on the Intel® communities and thank you for the discussion. If you like us to take a closer look at this, can you please share the following information:
Carlos L.
Mascready
Hello.
I've changed my PC since then. If it can help other users, I can send you my informations.
Thank you
Carlos_L_Intel
Hello @Mascready
Carlos L.
Carlos_L_Intel
Hello @Danrdz10103
Carlos L.
Danrdz10103
Thanks. sorry it was a busy week. I will digest theinformation and post another question if needed. thanks.
