Intel® Arc™ Discrete Graphics
4254 Discussions
Intel Arc 46.44 Driver Update
sebastien82300
I try different methods for install last update , still same :
lauch driver install , it extract , intel loading screen , then nothing
Edit : .4669 don't works either
brookearchaeo
I am having the exact same issue, the latest drivers I have been able to install are .4578
Please let me know if you find a solution
brookearchaeo
OK so um just to update on how I am progressing with my issue, since intel hasn't offered any support thus far xd
I now believe I have managed to install the latest drivers (.4669) but I do feel a little uncomfy about how I did it, I hope it will work ok.
Basically instead of just running the application and letting it install the drivers, I instead extracted it (bc ig the application is more like a hidden zip file or somethin?) so you could see its actual constituent files and stuff - and then using device manager I manually updated the drivers by navigating to the folder labelled 'graphics' and selecting that as the source to update the drivers from.
Initially it made Arc Control very upset it said my system wasn't supported, but after restarting my PC Arc Control was happy again and was displaying that I do indeed have the latest drivers (.4669).
I haven't tried playing any games yet though, I hope everything is gonna work on that front bc I do feel a bit uncomfy about having to have done it manually like this.
You could try that, let me know if it works for you too.
Hugo_Intel
Hello brookearchaeo
I see you found a workaround for his issue, installing the driver through the device manager should not cause any issues, however, if you are still experiencing issues with the installer, please feel free to open a new thread so we can assist.
Hugo O.
antzpantz
Thank you for posting this solution. It worked for me.
Intel... fix your Installer program!
brookearchaeo
Glad I could help
hopefully they fix it for their future driver installs. just go back to however they were making the driver installer for .4578!! It was workin then!
Hugo_Intel
Hello sebastien82300
We understand you have opened a (chat/email/phone) support case with us, and we will continue to help you through that channel now. We will therefore close this community case. Please, keep in mind that this thread will no longer be monitored by Intel, in case that you have further questions, please open a new thread.
Thanks for your understanding.
Hugo O.
sebastien82300
Solved
i've extract driver4644.exe  in a folder (with 7zip)
then install it via device manager ->GPU ->properties->update driver (manualy)->choose your driver extracted folder
install succeed
Please Intel patch your  installer for 4644 and 4669 update (and next)
antzpantz
Well, I've had to do a system restore on Windows because after the driver update, my 2nd monitor was not being detected correctly. It's a matching monitor to my main (BenQ BL2420PT) with the main connected via HDMI and the 2nd connected via DisplayPort. My gfx card is the Arc A750.
