Intel® Arc™ Discrete Graphics
3519 Discussions
Intel Arc A380 DVXA2 Hardware Acceleration not working in Windows?
compsmith
I received a A380 today and promptly installed it in my Windows Server 2019 Plex server with an older Xeon v5 with iGPU, no resizable bar available.
Latest Intel drivers installed but not the Arc controller. Disabled the iGPU and ran some tests. Plex is not utilizing the A380 for transcoding.
I have been testing this on the Plex forums and it seems that dvxa2 is not implemented. When and/or will this be implemented?
https://forums.plex.tv/t/hardware-support-for-intel-arc-alchemist-gpus-being-explored/797301
C:>mpv.com h264.mkv -vo=gpu -hwdec=dxva2
[vd] Opening decoder h264
[vd] Looking at hwdec h264-dxva2...
[vo/gpu] Loading hwdec drivers for format: 'dxva2_vld'
[vo/gpu] Loading hwdec driver 'dxva2-egl'
[vo/gpu] Loading failed.
[vo/gpu] Loading hwdec driver 'dxva2-dxgi'
[vo/gpu] Loading hwdec driver 'dxva2-dxinterop'
[vd] Trying hardware decoding via h264-dxva2.
[vd] Pixel formats supported by decoder: cuda dxva2_vld d3d11va_vld d3d11 yuv420p
[vd] Codec profile: High (0x64)
[vd] Requesting pixfmt 'dxva2_vld' from decoder.
[ffmpeg/video] h264: Failed to retrieve decoder device GUIDs
[ffmpeg/video] h264: Failed setup for format dxva2_vld: hwaccel initialisation returned error.
[vd] Pixel formats supported by decoder: cuda d3d11va_vld d3d11 yuv420p yuv420p
[vd] Requesting pixfmt 'yuv420p' from decoder.
[vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10)
[vf] User filter list:
[vf]   (empty)
[ad] Codec list:
[ad]     dca (dts) - DCA (DTS Coherent Acoustics)
[ad] Opening decoder dca
[ad] Requesting 1 threads for decoding.
[ad] Selected codec: dca (DCA (DTS Coherent Acoustics))
[af] User filter list:
[af]   (empty)
[cplayer] Starting playback...
[vd] Falling back to software decoding.
 C:>mpv.com h265.mkv -vo=gpu -hwdec=dxva2
[vd] Opening decoder hevc
[vd] Looking at hwdec hevc-dxva2...
[vd] Trying hardware decoding via hevc-dxva2.
[vd] Selected codec: hevc (HEVC (High Efficiency Video Coding))
[vf]   (empty)
[ad] Codec list:
[ad]     truehd - TrueHD
[ad] Opening decoder truehd
[ad] Selected codec: truehd (TrueHD)
[af]   (empty)
[vd] Pixel formats supported by decoder: dxva2_vld d3d11va_vld d3d11 cuda yuv420p10le
[vd] Codec profile: Main 10 (0x2)
[ffmpeg/video] hevc: Failed to retrieve decoder device GUIDs
[ffmpeg/video] hevc: Failed setup for format dxva2_vld: hwaccel initialisation returned error.
[vd] Pixel formats supported by decoder: d3d11va_vld d3d11 cuda yuv420p10le yuv420p10le
[vd] Requesting pixfmt 'yuv420p10le' from decoder.
[af] [in] 48000Hz 7.1 8ch s32
[af] [userspeed] 48000Hz 7.1 8ch s32
[af] [userspeed] (disabled)
[af] [convert] 48000Hz 7.1 8ch s32
Steven_Intel
Thank you for posting on the Intel® communities. We will move your question to the correct sub forum, the team in charge will get back to you soon.
Steven G.
Mark9_Intel
Hello Compsmith,
Thank you for posting on the Intel Arc communities.
I will proceed to check the information provided and review this request internally. I will post back soon with more details.
Mark S.
compsmith
Mark9_Intel
Hello Compsmith,
We have been checking the information provided and we would like to gather some further information about this issue and the current setup that you have. Can you please provide me with the following?
-What driver version are you currently using?
-Have you tested if this behavior has been replicated on other non-server Windows versions?
-Please share with us the model of your CPU and motherboard. As well as some details about your current setup. For example: If this is a pre-build server or a custom build, the function of this GPU while using Plex TV and what other devices may you have connected?
Also, if you have any findings or extra information that you would like to share, feel free to post them.
Mark S.
compsmith
Hello Mark,
Here is some of the information you have requested.
31.0.101.3430
I have not nor am I able to.
Dell PowerEdge T30
CPU: Intel Xeon E3-1225 v5
RAM: 32 GB Micron 18ASF2G72AZ-2G6D1
Motherboard: DELL 07T4MC
Chipset: Intel C236 (Skylake PCH-H)
Symbios Logic/LSI SAS2008 PCI-Express Fusion-MPT SAS-2 Controller
Intel I350 Gigabit 1000BaseT Network Ethernet Adapter
The intended function of the A380 GPU is strictly for encoding/decoding no gaming.
We tested with mpv player & ffmpeg
With mpv player we tested d3d11va and DXVA2. DXVA2 Failed hardware transcoding.
d3d11va (x264) (mpv.com h264.mkv -vo=gpu -hwdec=dxva2)
[vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
[vd] h264_qsv (h264) - H264 video (Intel Quick Sync Video acceleration)
[vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder
[vd] Requesting pixfmt 'd3d11' from decoder.
[vd] Using hardware decoding (d3d11va).
d3d11va (x265) (mpv.com h265.mkv -vo=gpu -hwdec=dxva2)
[vd] hevc - HEVC (High Efficiency Video Coding)
[vd] hevc_qsv (hevc) - HEVC video(Intel Quick Sync Video acceleration)
[vd] hevc_cuvid (hevc) -Nvidia CUVID HEVC decoder
dxva2 (x264) (mpv.com h264.mkv -vo=gpu -hwdec=dxva2)
[vf]   (empty)
[ad] Codec list:
[af]   (empty)
dxva2 (x265) (mpv.com h265.mkv -vo=gpu -hwdec=dxva2)
[vf]   (empty)
[ad] Codec list:
[af]   (empty)
With ffmpeg same results
x264
dxva2
[h264 @ 000001e419ea40c0] Failed to retrieve decoder device GUIDs
[h264 @ 000001e419ea40c0] Failed setup for format dxva2_vld: hwaccel initialisation returned error.
This is all detailed in this PLEX thread
It seems Plex uses DXVA2 (instead of D3D11) for decoding on windows, this would also affect any other applications that transcode video files using DXVA2 so not related directly to plex.
compsmith
Hi Steve,
Here is the information you requested
Intel® Graphics Beta Driver 31.0.101.3430
The only hardware I have to test on is running Windows Server 2019
Dell Poweredge T30
Processor Name: Intel Xeon E3-1225 v5
RAM: 32GB Micron 18ASF2G72AZ-2G6D1
Motherboard Model: DELL 07T4MC
Motherboard Chipset: Intel C236 (Skylake PCH-H)
Intel I350 Gigabit 1000BaseT Network Ethernet Adapter (Copper)
The function of the Intel Arc A380 is intended strictly for Quick Sync hardware encoding/decoding video
"Also, if you have any findings or extra information that you would like to share, feel free to post them. "
All of our findings are located over on the PLEX forum
Notable findings running test with mvp player and ffmpeg returned the same results:
d3d11 hardware decoding is working
mpv.com h264.mkv -vo=gpu -hwdec=d3d11va -v
dxva2 hardware decoding is failing
h264
[vf]   (empty)
[ad] Codec list:
[af]   (empty)
h265
[vf]   (empty)
[ad] Codec list:
[af]   (empty)
compsmith
Hi Steve,
Dell Poweredge T30
The function of the Intel Arc A380 is intended strictly for Quick Sync hardware encoding/decoding video. No Gaming.
h264
[vf] (empty)
[ad] Codec list:
[af] (empty)
h265
[vf] (empty)
[ad] Codec list:
[af] (empty)
compsmith
Hi Steve,
Dell Poweredge T30
The function of the Intel Arc A380 is intended strictly for Quick Sync hardware encoding/decoding video. No gaming.
h264
[vf] (empty)
[ad] Codec list:
[af] (empty)
h265
[vf] (empty)
[ad] Codec list:
[af] (empty)
compsmith
Hi Steve,
Dell Poweredge T30
h264
[vf] (empty)
[ad] Codec list:
[af] (empty)
h265
[vf] (empty)
[ad] Codec list:
[af] (empty)
compsmith
Hi Steve,
Dell Poweredge T30
h264
[vf] (empty)
[ad] Codec list:
[af] (empty)
h265
[vf] (empty)
[ad] Codec list:
[af] (empty)
compsmith
There is something wrong with the intel forums not letting me post my detailed reply. It shows posted then is removed.
compsmith
Hi Steve,
Dell PowerEdge T30
h264
[vf] (empty)
[ad] Codec list:
[af] (empty)
h265
[vf] (empty)
[ad] Codec list:
[af] (empty)
compsmith
Hi Steve,
Dell Poweredge T30
[vf] (empty)
[ad] Codec list:
[af] (empty)
compsmith
Hi Steve,
Dell Poweredge T30
compsmith
h264
[vf] (empty)
[ad] Codec list:
[af] (empty)
h265
[vf] (empty)
[ad] Codec list:
[af] (empty)
compsmith
Hi Steve,
Dell Poweredge T30
h264
[vf] (empty)
[ad] Codec list:
[af] (empty)
h265
[vf] (empty)
[ad] Codec list:
[af] (empty)
Mark9_Intel
Hello Compsmith,
Thank you for your response.
We are going to check this information again and continue with our internal research. As soon as I have any updates I will post them here.
Mark S.
Raptor2123
I'm also interested in using an Arc GPU in this same use-case.  I have a Plex server running Windows Server 2019 because Windows 10 no longer supports my RAID card and RFS is exclusive to Windows server.  I see that the ARC drivers don't mention compatibility with Windows Server.  Am I going to have to stick with nVidia or Radeon for my home media?
Andres_Intel
Hello compsmith,
As per our investigation, we checked that the latest driver 31.0.101.4032 includes improvements on DirectX 9. I understand you have already tried different drivers versions, but to continue the investigation please follow the steps below:
  • Download the driver on Download Center, and install t following the steps on How to Install an Intel® Graphics Driver in Windows® 10 & Windows 11 method 2.
  • If the issue persists after the previous step, provide app logs, as you did before for further research.
Andres P.
AnaWilliam850
Hi! I have the same problem, so I will try what you said, thanks
