Intel® Arc™ Discrete Graphics
4254 Discussions
Intel Arc Graphics – 8K Video Playback Stutter Persists
Deepakbalu
Dear Intel Arc Driver Team,
I am writing to report a persistent issue with 8K video playback on my Intel Arc-based system, even after updating to the latest 32.0.101.6913 WHQL driver.
My Setup:
Laptop: Lenovo Yoga 7 (Intel Core Ultra 5 125H with Intel Arc Graphics)
OS: Windows 11 Home Single Language (24H2)
Displays:
Direct playback in Laptop and Projector via HDMI from laptop
Browser/Player Tested: Chrome, Edge
Driver Version: 32.0.101.6913 (latest)
Previously Resolved (Thanks!):
Before this update, On the 6556 version I faced heavy frame drops and slow-motion playback even with 4K videos when Direct playback in Laptop and connecting to my projector.
However, after updating to 6913 and re-enabling hardware acceleration, 4K playback now works smoothly, including in browsers like Chrome and Edge. So, thank you for resolving this in the latest release!
New / Remaining Issue: 8K Video Playback
While 4K is now smooth, I’m still seeing major stuttering, frame drops, and playback issues with 8K YouTube videos
Happens even with direct HDMI → projector
CPU usage spikes to 90–100%
GPU decode usage is inconsistent (VP9/AV1 decode may not trigger properly)
Issue appears across Chrome, Edge
Additional Notes:
1080p and 4K playback are stable after update
Kindly Consider:
Improved support for 8K VP9/AV1 decoding on Arc and Core Ultra chips
Optimization for dual-output setups (separate audio/video via different outputs)
More robust handling of fullscreen playback on extended displays
I’d be happy to provide logs or debug data if needed. Thank you again for the progress in recent driver versions — I look forward to further improvements.
Mike_Intel
Hello Deepakbalu,
  1. Was the 8k video playback working fine before?
  2. How did you update the Graphics driver?
  3. Were you able to achieve 8k resolution using a different monitor before?
  4. Please help generate the SSU logs of your system. Kindly refer to the link below on how to generate the logs:
Michael L.
Deepakbalu
Was the 8k video playback working fine before? No, including 4k it had stutter, now after 6913 update 4k is working fine.
How did you update the Graphics driver? Intel® Driver & Support Assistant
Were you able to achieve 8k resolution using a different monitor before? I have tried in laptop monitor, 4k tv and projector every monitor had same issue.
Please help generate the SSU logs of your system. Kindly refer to the link below on how to generate the logs: PFA
VonM_Intel
Hello Deepakbalu,
Thank you for the clarification and detailed responses. It's great to hear that the recent 31.0.101.6913 driver update has improved 4K playback performance. Regarding the 8K video playback, I understand it has consistently shown stuttering across multiple displays, including your laptop monitor, 4K TV, and projector, even prior to the update.
I attempted to open the file you provided (Intel log.txt), but unfortunately, I encountered an error on my end. Would you mind re-uploading the file here? I apologize for the inconvenience and appreciate your understanding.
Von M.
Deepakbalu
Reuploading the file. Hope this one works.
Mike_Intel
Hello Deepakbalu,
Thank you for the update.
Before we proceed, let me check. Based on the link below, to achieve 7680 × 4320, the cable that you should use is HDMI2.1 FRL or Display Port.
Intel® Core™ Ultra 5 Processor 125H
Can you confirm the cable that you are using?
As additional information, let me share this link for more information on different cables and its bandwidth which translate to higher display resolution if you are using a high bandwidth cable.
How to use Bandwidth to Determine the Best Video Output
Michael L.
Mike_Intel
Hello Deepakbalu,
Michael L.
Deepakbalu
Let’s set aside the cables and external monitor for now. The video is jittering on the laptop screen itself, so it's clear the issue isn’t related to external factors. I’ve noticed the focus keeps shifting to other possibilities, but I’d like us to concentrate on resolving the problem with the laptop display first.
Could you please let me know how this will be addressed and what the resolution plan is?
Mike_Intel
Hello Deepakbalu,
Let me check, are you having this issue if you use an external monitor?
If not, there is a possibility that the issue is with the monitor itself of the laptop.
To further diagnose the issue, you may contact Lenovo. This is to provide the best settings and configuration and also to avoid Warranty issues.
Michael L.
Deepakbalu
Oh very funny. So now the laptop monitor is the problem?
Let’s stop wasting time pointing fingers at everything else. I’d appreciate it if we could avoid shifting the blame to external factors and instead focus on investigating the root cause—specifically on the Intel side. Let’s work toward a proper resolution.
May I know would you able to find anything from the log file?
There is nothing to do with the laptop screen. It's perfect and everything else is working fine.
Even the external monitors TV and projector also causing same issue when connected to laptop via HDMI. Cables are 2.1 version only.
Earlier Playing 4k video had the same issue. After intel graphics update that has been resolved now. Try to fix 8k as well.
Mike_Intel
Hello Deepakbalu,
I sent an email in the email address indicated in your profile here in the communities. This is regarding the update for this thread. Please check your inbox.
Michael L.
Mike_Intel
Hello Deepakbalu,
Michael L.
Deepakbalu
I have replied to the email with details.
Thanks!
jiax
Is the problem solved? I also recently experienced a stuttering issue with the U5 125H 8k playback.
Is the update driver good?
Thanks!
MichaelMc
You might also want to do a completely clean driver reset — either through Intel’s Driver & Support Assistant or with DDU. A fresh install sometimes makes AV1 decoding kick in properly again.
And if the issue persists, sending the Intel team your DxDiag and an Intel GPA capture really helps. They can usually pinpoint what’s going wrong much faster, especially when it involves dual-display setups.
