- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
When I try to install the updated driver Norton blocks it and says it's because powershell.exe is infected with IDP.HELU.PSE53 - Command line detection
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Althom,
Thank you for reporting this issue with Norton blocking the driver installation in Intel Communities. This appears to be a false positive detection that's interfering with the driver installation process. To help resolve this quickly, I'll need to gather some additional information:
- Where did you download the driver from? (Please share the exact download link if possible)
- Were you using the automatic installer, manual installation, or Intel Driver & Support Assistant?
- Are you facing any graphics or display issues the reason why you were trying to update the graphics driver?
- Can you share a screenshot of the Norton detection/blocking message?
- To get a complete picture of your system configuration, kindly submit your SSU log file. This information will help us determine if this is a known false positive and provide you with the best solution to proceed with the driver installation safely.
JeanetteC.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Althom,
Did you have a chance to review the previous post?
Please feel free to reach out if you have any questions.
JeanetteC.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Althom,
Please be advised that Intel is still actively investigating this issue you've reported, and we'll share an update once it is available.
JeanetteC.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
The issue you reported should now be fixed in the latest graphics driver (version 101.8331).
When you get a moment, could you install driver 101.8331 and let us know if everything looks good on your end?
Arturo M
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Althom,
JeanetteC.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Althom,
Since I haven't received any response from you recently, I will go ahead and close this thread.
Sincerely,
JeanetteC.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
