Intel® Arc™ Discrete Graphics
3510 Discussions
Intel Support Assistant Installation Error While Updating Arc A750
MoonArya
I own an Intel Arc A750 graphics card. Today (December 24, 2024, about 5 minutes before writing this post), I noticed a new driver update was available.
I successfully downloaded the update, but when I attempted to install it, the Intel Support Assistant application failed to open. The file seemed unreadable, so I uninstalled the application via the Control Panel.
When I tried reinstalling the Intel Support Assistant, I encountered the error shown in the attached file.
Could you please assist me in resolving this installation issue? Thank you in advance!
n_scott_pearson
Did you try to install from a file on another PC? There are known issues with this.
MoonArya
I don't have a chance to try it from another computer right now. I also want to find a permanent solution from my own computer.
DeancR_Intel
Hi MoonArya,
Thank you for posting in the Community!
Have you tried doing clean installation of the graphics driver?
I suggest trying the following steps to fix the issue:
Intel® Driver and Support Assistant (Intel® DSA) Does Not...
Let me know if the issue still persists.
Dean R.
DeancR_Intel
Hi MoonArya,
Dean R.
DeancR_Intel
Hi MoonArya,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
