Intel® Arc™ Discrete Graphics
4418 Discussions
Intel installation error code 1000
odengie
i wanted to install new intel processer graphics (Intel 11th - 14th Gen Processor Graphics - Windows version: 32.0.101.7082) which was released on 8 december 2025. But when i installed, it shows error code 1000. I installed it again to make sure it was just a minor error, but still it shows error code 1000.
My specs are
1. 13th gen intel core i7-13700H
2. Intel Iris Xe Graphics version 32.0.101.5768
Please help, is this bad?
AlHill
"is this bad?"
Venkman:  What do you mean "bad?"
Spengler:  It's hard to explain, but try to imagine all life as you know it stopping instantaneously and finding yourself confined forever in another dimension.
Sorry, I could not resist.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Windows 11 is a keystroke logger]
