Hi! I'm having trouble in updating Intel Iris Xe graphics and Arc, when i already install this driver and i restart my laptop which is asus vivobook, it does not apply the graphics that i installed. Can anybody help me in this case?
Hi, I'm having a similar trouble. I have an Asus Vivobook X1605ZA. For a few months now, the Iris Xe graphics card has stopped working. When I activate the driver in Device Manager, the laptop reboots itself and the system recovery window appears. From there, it's a constant loop with no solution, as I uninstalled the OS and BIOS from scratch many times, of course the most and least recent drivers too, and I was never able to solve it. Finally, I gave up. From Safe Mode, I open Device Manager to permanently change or disable the Iris Graphics adapter for the generic display adapter so that the computer works. I think it's a hardware problem, maybe a power failure on some circuit... I don't know. I found the possibility of reballing the processor, but it's a slow and risky job. So if you found a solution, I'd love to know; maybe our contributions will benefit the community. Thanks!
Hi ELLIS1,
What is the exact model of your laptop?
Have you tried using the OEM driver for testing?
Have you used DDU to completely remove all residual drivers and installed a new one?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
@ANDIAZ please create a separate thread so we can focus with your concern.
Archie D.
Hi @ArchieD_Intel Thanks for your reply, I create a new thread with my trouble. https://community.intel.com/t5/Intel-ARC-Graphics/Intel-Iris-Graphics-not-works/m-p/1691216#M24910
Hi ELLIS1,
@ANDIAZ Thank you for your response, there will be assigned person to address your issue.
Archie D.
Hi ELLIS1,
Archie D.
