Intel® Arc™ Discrete Graphics
3527 Discussions
Is there any way to enable XeSS with 100% render resolution?
dabi
Lately I've trying to find a way to use XeSS with 100% render resolution, but it seems like there's no way to do that. I just want to have something like DLAA but with intel, maybe something called XeAA just to get rid of the other anti-aliasing techniques, which in some cases harm the quality or performance of the games.
Jean_Intel
Hello dabi,
We appreciate your patience. We would like to inform you that XeSS uses AI-powered upscaling to produce high-quality images while rendering at a lower resolution, which results in better performance. However, we don't have a technology similar to DLAA at the moment.
The implementation of XeSS, including the target render resolution, varies depending on the application developer. For more information, please visit https://github.com/intel/xess.
Best regards
Jean O.
Jean_Intel
Hello dabi,
Thank you for posting back in the Intel Communities. We see that you are looking for an option to run XESS with 100% render resolution, similar to the Nvidia option DLAA, and you are joining the thread to confirm if this is possible. Based on your question, we would like to research this internally, and we will be posting back as soon as we have more details.
Best regards
Jean O.
Jean_Intel
Hello dabi,
Best regards
Jean O.
Jean_Intel
Hello dabi,
We see that you have marked our previous post as the solution. We are glad to see that the information we shared has been useful. Since you marked the thread as solved, we will proceed to close this case.  If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards
Jean O.
