There is a problem , i enabled native aspm in bios , my gigabyte b760m ds3h doesnt have those l1 substates and all , i also oned the power plan to maximum power savings , but still its ~35W
my pc : i5 12400f
intel arc a750 limited edition
gigabyte b760m ds3h
please help
Hello Dhyan12s,
The settings for PCI Express L1 Sub-states can vary depending on the OEM (Original Equipment Manufacturer). OEMs may customize BIOS/UEFI settings to optimize power management and performance for their specific hardware configurations. As a result, the availability and configuration of PCI Express L1 Sub-states can differ between systems from different manufacturers.
These sub-states are part of the PCI Express power management features designed to reduce power consumption when the device is idle. OEMs might enable or disable these settings based on the design goals of the system, such as prioritizing energy efficiency or performance.
If you are not able to locate the settings or need specific information about how these settings are configured on your system, it's best to consult the documentation provided by your OEM (Gigabyte) or check the BIOS/UEFI settings directly.
Source:
High Power Consumption when Intel® Arc™ Graphics Card is Idle
I hope you find this information useful.
Best regards
JeanetteC.
Hi Dhyan12s,
- When did the issue start? Was it after a specific update?
- What are the troubleshooting steps that you tried other than changing the power plan?
- Have you used DDU to completely remove all residual drivers and installed a new one?
- Have you tried checking the High Power Consumption when Intel® Arc™ Graphics Card is Idle?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
I build the new few days ago, New one so im in the latest driver and about the motherboard also it doesnt have L1 substates , it only has native aspm
Hello Dhyan12s,
I will look into this internally and provide an update once available.
Best regards
JeanetteC.
Hello Dhyan12s,
Source:
Best regards
JeanetteC.
Hi Dhyan12s,
Thank you for your feedback. Please let me know if your concern has been fully addressed.
Archie D.
Hi Dhyan12s,
I reviewed the case and since you've approved the previous post as solution, I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Additionally, please continue to contact your GPU manufacturer for assistance.
Archie D.
