Intel® Arc™ Discrete Graphics
Comunicados
4411 Discussões
Marvel Rivals can't launch on Linux
sadnehs
Principiante
44.721 Visualizações
I just wanted to report my experience with Marvel Rivals, using Ubuntu (24.04), and an Arc A750 GPU. (also using an i5 12400 CPU). I have experienced this issue since the launch of the game.
I am most recently on the open source GPU driver 4.6 Mesa 24.3.3 (from the kisak-mesa PPA, reliable and used by many). Though I have tested on the last couple versions of Mesa released since launch (I believe only two others).
I launch the game via Steam. I am able to open the splash screen before the game, but when I click "Launch" it takes a few moments and then gives me a Direct X 12 error, saying my card doesn't support Direct X 12. This is an Unreal Engine 5 error window.
I am playing on Linux. You might expect this is a proton issue because it cites Direct X, and Proton translates from DX to Vulkan with DXVK.
However, this is the only game I am experiencing this with, and it has been an issue since the launch of the game. And I have tested all the currently available Proton versions on Steam, as well as experimental and hotfix each week, and Proton GE 9 20 - 22. This problem has not been fixed yet.
I just wanted this issue to be known to the Intel driver team, because I'm worried it's being ignored by both the developers of the game and Intel's side. Because it's easy to maybe blame Linux for this.
But my experience with my Arc card on Linux for the past 6-8 months has been excellent, with really no other issues.
Also let me know if you are a player with this card who does NOT have issues with Marvel Rivals on Linux.
If people think this is more of a Proton or Marvel Rivals issue, I would appreciate being pointed to... where I can report this. And what kind of details can I add to the report.
Thank you for your help and attention.
1 Solução
tykazz
Principiante
43.415 Visualizações
I am pretty sure this in Intel driver issue. I swapped my B580 for a 7900 xtx and made no other changes and the game worked without any issues. It also appears that the mesa team is aware of this issue and working on a fix. Hopefully we will see it soon.
Ver solução na publicação original
19 Respostas
sadnehs
Principiante
44.715 Visualizações
Im sorry for the formatting, here is my PC specifications in bullet point form:
- Arc A750 GPU (Intel's card, not 3rd party) Re-bar is set to enabled in the bios, always.
- GPU Driver: Mesa 24.3.3 (also would've tested .3.2 , and .3.1)
- Ubuntu 24.04 (always latest stable)
- i5-12400 CPU, 16 GB DDR4 ram, running on an Nvme SSD.
Unreal Engine 5 error says my card does not support Direct X 12.
Able to open splash screen but unable to "Launch" the game from there.
Also an additional note, some versions of Proton seem to "skip" the splash screen and go straight to the same error window.
And again thank you for your time and attention.
sadnehs
Principiante
44.714 Visualizações
I'll just paste in my hardware info from Steam, sorry again for the format of this post.
Computer Information:
Manufacturer: Micro-Star International Co., Ltd.
Model: PRO B660M-G DDR4 (MS-7D45)
Form Factor: Desktop
No Touch Input Detected
Processor Information:
CPU Vendor: GenuineIntel
CPU Brand: 12th Gen Intel(R) Core(TM) i5-12400
CPU Family: 0x6
CPU Model: 0x97
CPU Stepping: 0x5
CPU Type: 0x0
Speed: 4400 MHz
12 logical processors
6 physical processors
Hyper-threading: Supported
FCMOV: Supported
SSE2: Supported
SSE3: Supported
SSSE3: Supported
SSE4a: Unsupported
SSE41: Supported
SSE42: Supported
AES: Supported
AVX: Supported
AVX2: Supported
AVX512F: Unsupported
AVX512PF: Unsupported
AVX512ER: Unsupported
AVX512CD: Unsupported
AVX512VNNI: Unsupported
SHA: Supported
CMPXCHG16B: Supported
LAHF/SAHF: Supported
PrefetchW: Unsupported
BMI1: Supported
BMI2: Supported
F16C: Supported
FMA: Supported
Operating System Version:
Ubuntu 24.04.1 LTS (64 bit)
Kernel Name: Linux
Kernel Version: 6.8.0-51-generic
X Server Vendor: The X.Org Foundation
X Server Release: 12302006
X Window Manager: GNOME Shell
Steam Runtime Version: steam-runtime_0.20241024.105847
Client Information:
Version: 1733265492
Browser GPU Acceleration Status: Enabled
Browser Canvas: Enabled
Browser Canvas out-of-process rasterization: Enabled
Browser Direct Rendering Display Compositor: Disabled
Browser Compositing: Enabled
Browser Multiple Raster Threads: Enabled
Browser OpenGL: Enabled
Browser Rasterization: Enabled
Browser Raw Draw: Disabled
Browser Skia Graphite: Disabled
Browser Video Decode: Enabled
Browser Video Encode: Disabled
Browser Vulkan: Disabled
Browser WebGL: Enabled
Browser WebGL2: Enabled
Browser WebGPU: Disabled
Browser WebNN: Disabled
Video Card:
Driver: Intel Mesa Intel(R) Arc(tm) A750 Graphics (DG2)
Driver Version: 4.6 (Compatibility Profile) Mesa 24.3.3 - kisak-mesa PPA
Desktop Color Depth: 24 bits per pixel
Monitor Refresh Rate: 143 Hz
VendorID: 0x8086
DeviceID: 0x56a1
Revision Not Detected
Number of Monitors: 1
Number of Logical Video Cards: 1
Primary Display Resolution: 2560 x 1440
Desktop Resolution: 2560 x 1440
Primary Display Size: 23.62" x 13.39" (27.13" diag), 60.0cm x 34.0cm (68.9cm diag)
Primary VRAM: 8128 MB
Sound card:
Audio device: USB Mixer
Memory:
RAM: 15773 Mb
VR Hardware:
VR Headset: None detected
Miscellaneous:
UI Language: English
LANG: en_US.UTF-8
Total Hard Disk Space Available: 467297 MB
Largest Free Hard Disk Block: 73008 MB
Storage:
Number of SSDs: 5
SSD sizes: 6001G,2000G,1000G,500G,250G
Number of HDDs: 0
Number of removable drives: 0
(These harddrive lines are confused, only the 250G [SATA], 500G [Nvme boot drive], and 1000G [SATA] are SSDs. The 2000G is an external USB HDD, and the 6000G is an internal HDD... not that this is important. The game is installed on the 1000G SATA which is not the boot drive).
sadnehs
Principiante
44.660 Visualizações
The error I receive is:
"DirectX 12 is not supported on your system.
Please update your Windows 10 64-bit operating system (version 1909 or later) and upgrade your graphics card driver.
Ensure that your graphics card meets the minimum requirements (NVIDIA GTX 1060 or AMD RX 580)."
Reminder for the post I am on Ubuntu 24.04.
This appears in a window titled "Message".
On the latest proton and Proton GE versions,  it skips the splash screen and goes straight to the error.
DhannielM_Intel
Moderador
44.569 Visualizações
Hello sadnehs,
Thank you for posting in the community, and I appreciate your concern about this issue. Since you already provided information even the Mesa driver of the graphics. Let me further check this on my end. I will get back to you as soon as possible.
Dhanniel M.
DhannielM_Intel
Moderador
44.214 Visualizações
Hello sadnehs,
Thank you for your patience. Have you tried using this lanuch command SteamDeck=1 %command% on Steam? If not, please give it a try. You can refer to the attached image for guidance.
Let me know the outcome of doing this method.
Dhanniel M.
sadnehs
Principiante
44.016 Visualizações
Sorry I forgot to include, yes I have been using the Steamdeck fix command. As recommanded by protondb posts since several weeks ago I think.
DhannielM_Intel
Moderador
44.052 Visualizações
Hello sadnehs,
I just wanted to check if you have seen the recommendation that I have provided on my previous reply? Let if you already did it so we can look for other resolution for this issue.
Dhanniel M.
DhannielM_Intel
Moderador
43.972 Visualizações
Hi sadnehs,
I am sorry but could you please confirm if the issue persisted after using that command?
Dhanniel M.
sadnehs
Principiante
43.946 Visualizações
yes the issue continues, same as before. The command did not fix or change any behaviour reported. I will leave that command on the game options though, as it seems required regardless.
tykazz
Principiante
43.905 Visualizações
I am having the same issue using a B580 on CachyOS. Previously I was using Arch and also had the same issue there.
sadnehs
Principiante
43.842 Visualizações
Iwas on Ubuntu but recently switched to Cachy OS, behaviour is identical.
sadnehs
Principiante
43.690 Visualizações
I've since switched to Endeavor lol. Same thing, Arch-based. Same behavior as on Cachy and Ubuntu. I also tried Debian. Seems to be across any Linux distro.
DhannielM_Intel
Moderador
43.866 Visualizações
Hello sadnehs,
I see, thank you for informing me. Let me investigate further and find an appropriate resolution for this matter.
Also, @tykazz, thank you for sharing your concern. I would highly advise you to create a separate thread for your issue, as you are using a different Linux distro and Intel GPU. This will help us keep things more organized.
Dhanniel M.
sadnehs
Principiante
I actually recently switched from Ubuntu to CachyOS. The behaviour is identical. This appears to happen to all Intel Arc GPU users on Linux (using Proton, the only way to play).
sadnehs
Principiante
43.688 Visualizações
Well now I'm on Endeavor OS, for other reasons.  Point is behavior is the same across all Linux distros I try. So  don't worry about testing on a particular distro. Ubuntu is the popular one, best test on that.
DhannielM_Intel
Moderador
43.490 Visualizações
Hello sadnehs,
Thank you for your patience. I have attempted to replicate the issue, and it appears to be a game-related problem. The same error occurs when I tried playing on Ubuntu 24.04 LTS with an RTX 4060 using the latest driver 550, Proton Hot-Fix, Proton 9.0-4, and even the Experimental version, all without success.
Given this, you might want to consider trying a different operating system for this game. Alternatively, you may wish to contact the Ubuntu for further assistance with this issue.
Dhanniel M.
tykazz
Principiante
43.416 Visualizações
DhannielM_Intel
Moderador
43.269 Visualizações
Hello sadnehs,
Just checking in to see if you had a chance to go through the information I sent. If there's anything you're unsure about or if you need additional details, please let me know. I'm here to help!
Also, @tykazz thanks for this information I will take note about this information.
Dhanniel M.
DhannielM_Intel
Moderador
42.893 Visualizações
Hello sadnehs
Since I haven't heard back from you, I will close this inquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dhanniel M.
Responder
