Intel® Arc™ Discrete Graphics
4063 Discussions
Need for Speed 19 和 剑侠情缘网络版叁 帧数会出现不同程度的卡顿,卡屏,帧数骤降。
Shyu
Processor make and model. AMD 5950X
Motherboard make and model. ROG Strix X570-E Gaming
Amount of memory (RAM). 32 GB
Operating System version/build number.
Windows 11 Pro Workstations (64-bit)
Version (Build)
23H2 (22631.4317)
极品飞车19和剑侠情缘网络版第三帧数会出现不同程度的卡顿,卡屏,帧数急剧下降。
32.0.101.6297 和.0.101.6130/32.0.101.6048 都会出现此问题。
回滚到32.0.101.6078 WHQL认证问题得到解决。
希望在后续版本中这个BUG能够得到解决。因为这可能不止这两款游戏,目前我玩到的两款老游戏都会出现不同程度的卡顿,卡屏,帧数骤降。
Translate:
There are varying degrees of stuttering, screen freezing, and frame rate drops in Need for Speed 19 and Jian Xia Qing Yuan Online 3.
This issue occurs with versions 32.0.101.6297 and 32.0.101.6130/32.0.101.6048.
Rolling back to version 32.0.101.6078 WHQL Certified resolves the problem.
I hope this bug can be fixed in future versions, as it may affect more than just these two games. The two older games I have played so far both experience varying degrees of stuttering, screen freezing, and frame rate drops.
RobbieR_Intel
Hello Shyu,
Thank you for sharing the details of your setup and specific games affected by this issue.
To help us understand better and address the issue, please answer the following questions:
  • Have you performed a Clean Installation of Intel® Graphics Drivers in Windows* of the new drivers?
  • Is Resizable Bar (ReBAR) enabled on your system's BIOS?
  • What is your game settings? Kindly share a screenshot of it
  • Have you experienced similar stuttering, fps drops on other games or application?
  • What are the GPU and CPU temperatures during gaming?
We look forward to your response!
Robbie R.
RobbieR_Intel
Hello Shyu,
Robbie R.
RobbieR_Intel
Hello Shyu,
Robbie R.
HUAQman
嗨!还有工作人员跟进这个问题吗?自从6078版本驱动之后,每次更新最新的驱动,都是使用ddu卸载驱动之后全新安装但是没有一点用,在玩剑侠情缘三网络版中非常的卡而且经常卡的动不了。我现在使用的是最新的版本6874.一上游戏就卡,都不怎么上游戏了,就算是核显都不至于这么卡吧!
