Intel® Arc™ Discrete Graphics
4063 Discussions
Onix Odyssey Arc B580 - Linux - Set power and voltage
lafrad
I've run across an issue with a new Onix Oddyssey B580:   The default power and voltage limits aren't set (or they are set incorrectly)
On linux the max power limit reports as "35W" (I think), and I cannot find the voltage.   Performance is very bad, the Linux UI is laggy and 3d applications are a slideshow.
lafrad@teg-TR-3970X:~$ cat /sys/class/drm/card1/device/hwmon/hwmon11/power1_rated_max
35000000
lafrad@teg-TR-3970X:~$ cat /sys/class/drm/card1/device/hwmon/hwmon11/power2_rated_max
35000000
I've checked this by installing windows, installing the latest drivers, and witnessing the power and voltage settings within the Intel Control utility to be set to very low, inconsistent values.     If I set the Intel values to "100%" of power and voltage, windows performance is great and everything works "as expected".
Where can I adjust the power and voltage targets for my linux installation?  I'm not trying to overclock, I'm just trying to use the product as it was intended.
ArchieD_Intel
Hi lafrad,
  • Which Linux distribution and version are you using?
  • What is the kernel version currently running on your system?
  • What are the troubleshooting steps that you tried so far?
  • Are you using the default drivers provided by the Linux distribution, or have you installed any specific drivers for the Onix Oddyssey B580?
  • Have you tried updating the drivers or using alternative drivers to see if it affects the power and voltage settings?
  • Have you checked the BIOS/UEFI settings for any power management options that might affect the power and voltage limits?
  • Is there an option to reset to default settings or update the BIOS/UEFI firmware?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
ArchieD_Intel
Hi lafrad,
Archie D.
ArchieD_Intel
Hi lafrad,
Archie D.
