Intel® Arc™ Discrete Graphics
3569 Discussions
Poor performance in Steel Division 2
Thomas88
Hello i have problem with SD2 i can get only 20 fps at best even i have quite good pc for todays standars i think is there any option hot to change it ?
my pc
Card name: Intel(R) Arc(TM) B580 Graphics
Processor: 12th Gen Intel(R) Co Memory: 32768MB RAM
re(TM) i5-12400F (12 CPUs), ~2.5GHz
Current Mode: 2560 x 1440 (32 bit) (59Hz)
henery
You could try lowering the graphics settings or resolution a bit SD2 can still be demanding even on good hardware. Also, make sure your drivers are fully updated and V-Sync is off. That usually helps boost FPS.
Thomas88
Hi thanks for help but i tried everything with no visible effect, i updated drivers, win everything and still it didnt help but thanks for your time
RandyT_Intel
Hi @Thomas88,
  • Please provide the SSU log report and share it here so I can review your system's configuration.
  • Which digital distribution platform did you obtain the game that is experiencing graphics issues? (e.g., Steam, Epic Games Store, GOG, etc.)
  • Have you previously performed a clean installation of the graphics driver, before using either an older or the latest version?
  • Kindly share some screenshots and recordings of your game settings so we can replicate and check the issue on our end using the same settings you use during gameplay.
  • Additionally, you may follow this guide on how to report performance issues in the game.
Randy T.
Thomas88
Hi thanks for fast action
where can i send SSU log info i dont want to share it in public chat.
I obtained it by Steam
I did clean instalation with no visual effect on the game
I will provide recordings tonight
thanks for help
RandyT_Intel
Hi @Thomas88,
You may share the requested details via email. I’ll be sending a message shortly, please keep an eye out for it in your inbox.
Thank you!
Randy T.
