- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
OS: Windows NT 6.2 (Build: 9200)
CPU: GenuineIntel PentiumPro-class processor @ 3688 MHz with 2047MB RAM
Video: Intel(R) Arc(TM) A770 Graphics (3)
CreateTexture failed(8007000E).
History: FD3DTexture::Cache <- FD3DRenderInterface::CacheTexture <- FD3DRenderInterface::HandleCombinedMaterial <- FD3DRenderInterface::SetSimpleMaterial <- FD3DRenderInterface::SetMaterial <- ATerrainInfo::Render <- RenderLevel <- FLevelSceneNode::Render <- FCameraSceneNode::Render <- UGameEngine::Draw <- UWindowsViewport::Repaint <- UWindowsClient::Tick <- ClientTick <- UGameEngine::Tick <- UpdateWorld <- MainLoop
Tried reinstalling the driver to no avail
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Windows NT?
Pentium Pro processor?
Have you read the requirements for ARC?
[W10 is this generation's XP]
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Ok, so you listedd the processor incorrectly. How about the OS?
Let's get your configuration straight. So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Ok, the ssu report says you have a i5-12600K and W11 home..
Whatever tool you are using to get your system info you should delete.
Also, if you go to START, SETTINGS, SYSTEM, ABOUT, you can get your system information.
An Intel support engineer will be responding to your issue.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I was in system information, where I got that screenshot.
I'm not using any other tools than SSU
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
That would have to be from the game. Are you running the latest version of the game?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I repeated this, and the CtD only seems to affect Operation Cold Dagger.
