ayo as we know space engineers 2 faills to launch statng minium specs not met on arc A series GPUs; specfically an A770 16G in my case. support has said this is not a major concern due to volume... but do we have any ETA/etc... on when it will work or if its a HW fault due to missing FP64 type issue...
as currently this has been my only real major issue and my arc a770 has been the singular most stable gpu ive touched past using quadros as my daily... and i would like to continue supporting said GPUs... but currently theres both no real upgrade path to fix it if it is a HW issue and if its software that kinda sucks... anyway rant over
Hello sam244,
Thank you for reaching out to the Intel Community Forum. I understand your concern regarding Space Engineers 2 failing to launch and showing the message that minimum specs are not met on your Intel Arc A770 16GB GPU.
To assist you further, could you please provide the following details:
- Does the issue occur only with Space Engineers 2, or have you noticed similar behavior with other applications?
- Can you share the exact error message or a screenshot of the issue?
- Could you please provide us the SSU logs of your system? You can find instructions on How to get the Intel® System Support Utility Logs on Windows*
We will wait for your response so we can continue assisting you.
Kenneth B.
hi, this is a known issue that occures exclusivly with space engineers 2 noted on Article ID: 000101605
theres just been no updates and and i know no other way of bumping it that creating a thread here to show yes there is intrest
Hello sam244,
I'm reaching on behalf of Kenneth, Thank you for reporting this issue. We will continue to improve our software performance and compatibility throughout this year and beyond. While we can’t accommodate your request at this time, please watch this article Error: "Nosupporteddevice" When Launching Space Engineers 2 on Intel®...you found for any possible changes to this situation.
Randy T.
