Stormworks runs normally until I turn on boat lights, at which point the game freezes, then crashes. Has anyone experienced the same issue?
Hello onetwobravo,
Thank you for posting on the Intel️® communities. We understand that you are having crashes once you turn on the boat lights when playing Stormworks.
To have a better understanding of your issue, please provide me with the following:
- What are the games distribution service? ( Blizzard, Epic, Origin, Steam, Xbox, Ubisoft connect).
- Does the issue occur using other driver versions?
- Do you receive any error messages? If so, please provide us with a screenshot of the error message you receive.
- Share a video showing the issues you are experiencing.
- Create a system report using the following applications:
- Intel
System Support Utility (Intel SSU) - Download the Intel SSU
- Open the application and click on "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click on "Next"; then "Save."
- Intel® Graphics Command Center:
- Open the Intel Graphics Command Center
- Navigate to the Support tab
- Select System Diagnostic
- Click Generate Report
- Select Save and name the output file.
Jean O.
Hello onetwobravo,
We hope you are doing fine.
Jean O.
Hello onetwobravo,
Best regards.
Jean O.
